Engine Hours Disappeared - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 08-19-2019, 06:57 PM Thread Starter
Gentlemen,
I recently had the truck emissions tested (Ontario, Canada) at local Ford dealership and it came back with flying colours but somehow they had totally erased my engine hours while scrolling through the gauge info to get the truck's mileage. How is that possible, and is there any way (I doubt it) to resurrect it?
The truck has about 132 000 km (80 000 mi) on it.
2005 GMC 3500 Dually SLT,4x4,CC, LB, Auto, AFE Mouth Piece,Banks Six Gun Tuner, Banks intercooler & Exhaust
gbhrps is offline
post #2 of 14 (permalink) Old 08-19-2019, 08:38 PM
denarli6.6's Avatar
Hell might as well throw some jack stands in the rear and throw her in reverse and set the cruise. You could sell one hell of a 2005
2016 LML Denali 2500
Mcgaughy's 2" drop shackle
Bilstein 5100
22x10 American Force Flux black w machined or Toyos on OEM wheels. Depends on the day of the week
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
denarli6.6 is online now
post #3 of 14 (permalink) Old 08-19-2019, 11:58 PM
My friends 05 with 80k miles listed his for 20k and got 20k within a week.It never seen salt.
16 GMC Denali 3500 stock for now
Scott1979 is offline
post #4 of 14 (permalink) Old 08-20-2019, 05:49 AM
05 3500 2wd's Avatar
My engine hours reset on mine a while back for no reason also. Guess they do not matter. I use the 2nd trip odometer for my oil change intervals. Just turned 65,000.
Clifford is a 2005 GMC Loaded SLT 2wd with; true cold air intake mods, ported LBZ turbo inlet mouthpiece, AFE Inter cooler pipe, Diamond Eye down pipe, BD drivers side manifold, V2 radiator, thermostst controlled oil cooler, Edge CTS2, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, BF Xenon 6000k Headlights Low & Hi, Air lift Remote control 5000# air bag system, Tork Lift Stable Loads, EZ down Tailgate assist, Put co S/S mud flaps, compete interior wood dash kit, Dual Liner 3 piece bed liner with rubber floor mat, Roll-N-Lock tonne cover with tail gate lock, and AVS in channel vent visors.
GM DRW club member #5
05 3500 2wd is offline
post #5 of 14 (permalink) Old 08-20-2019, 08:17 AM
Noble_dmax's Avatar
Mine came back reset after I had all of my head gasket work done on the lly.
2018 GMC l5p ccsb stone blue metallic. Mcgaughy's 2" drop shackles. Truxedo tonneau cover. 20% tint. B&W turnover ball hitch. N Fab running boards, Duraflaps, Rhino lined bed
Traded:05 lly ccsb 205k miles, built trans and supporting mods
Traded:09 LMM CCLB Bone stock, fully loaded. 86xxx miles.
Noble_dmax is offline
post #6 of 14 (permalink) Old 08-20-2019, 09:33 AM
Sliverflipper's Avatar
Mine disappeared when I did a battery change. That was a couple of years ago and it still hasn't come back!
Sliverflipper is offline
post #7 of 14 (permalink) Old 08-20-2019, 02:11 PM
mine did not come back. It just started counting again. Could have been after the battery change. Not a parameter I generally look at.
post #8 of 14 (permalink) Old 08-20-2019, 09:00 PM
SilverGorillaLML's Avatar
It happens pretty often actually. Not a big deal
NIC R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/48RE Swap/PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
post #9 of 14 (permalink) Old 08-21-2019, 05:38 PM Thread Starter
Gentlemen,
Thanks for the replies.
Yes, my engine hour log has started up again from zero after the dealership pooched the original count. Its not a big deal, but if it was possible to fix, I would have preferred that.
gbhrps is offline
post #10 of 14 (permalink) Old 08-22-2019, 01:56 PM
i think you can get an edge that will track engine hours off the computer, ill look at my edge and see if it has that function.
Big Daddy Yum Yum is offline
