Air or Electrical ? - Chevy and GMC Duramax Diesel Forum
 3Likes
  • 3 Post By Hook'em_Horns!
post #1 of 7 (permalink) Old 08-25-2019, 01:43 AM Thread Starter
Air or Electrical ?
Hey Truck Techs, wondering if any have had this issue. Having a no start issue. Just up and happened about a month ago. I used the on board primer, 4-5 pumps had fuel, but also air. Engine started. Had to do this a few times, but not every time. Engine runs great when running and always has. I've heard about some wiring harness issues with this model. I did replace the in-tank fuel pump, engine started great and re-started great, three days later, no start until I primed again. Have also noticed letting off ignition switch quickly, IE letting off before hearing engine start, allows engine to start. Not seeing or smelling any fuel leaks is making me think electrical. Truck is a 2005 Silverado 3500 crew cab long bed, not a dually. And only has 95,000 miles. Love when this thing is pulling my 35' 11500# travel trailer, it walks the dog.. Any one experienced this issue before? Thanks
TrkTech is offline
post #2 of 7 (permalink) Old 08-25-2019, 04:23 AM
LHN...We ARE the Joneses
Your filter head is leaking, losing prime.
Replace.
JimmyD, M.A.M. and rta1197 like this.
Hook'em_Horns! is online now
post #3 of 7 (permalink) Old 08-25-2019, 06:20 AM
The filter head seals can be replaced for less than $10. It's good to give that a try first before spending the extra for an entirely new filter head.
2005 LLY 3500 CCLB 215,000 miles
Shibby6600 is offline
post #4 of 7 (permalink) Old 08-25-2019, 07:14 AM
407driver's Avatar
You can get a new head complete with a new FF and WIF for around $100. A good and foolproof solution.
You can rebuild it but for the price the new head with the above is a much more cost/time solution.
407driver is offline
post #5 of 7 (permalink) Old 08-27-2019, 05:33 AM
$100 can be worth different things to different people. It's good to give options so someone doesn't think a new one is the only fix available.
post #6 of 7 (permalink) Old 08-27-2019, 05:49 AM
Cheaper, if it works.
Not all potential leak areas are serviceable with the 6 seal set is all.
post #7 of 7 (permalink) Old 08-27-2019, 11:11 AM
rta1197's Avatar
Exactly.
Earlier this year my filter head began leaking. I bought a seal kit and installed it. Didn't stop it.
I had to go ahead and get the whole setup from XDP. Problem solved.
Bob Anderson
From my Galaxy S9+ using Tapatalk.
From the Texas Panhandle
[FONT="Arial"][COLOR="Blue"]LLY GMC CC SWB 2500 HD 4x4
Bully Dog intake (existing)
Resonator deleted
EGR deleted
PCV re-routed
MBRP 3" downpipe
FASS LP with Baldwin filters
PPE Race Fuel Valve
Stock rims with 265/75R16 Cooper S/T Maxx
Kryptonite Ultimate Front-end Package and Upper Control Arms
rta1197 is offline
