New hydroboost, now break light on - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 09-02-2019, 06:08 PM Thread Starter
I just replaced my hyroboost and now my break lights will not turn off? WTH! break light switch?
Goldneye01 is offline
post #2 of 7 (permalink) Old 09-02-2019, 06:11 PM
LHN...We ARE the Joneses
Did you install the switch back correctly?
Hook'em_Horns! is online now
post #3 of 7 (permalink) Old 09-02-2019, 06:26 PM Thread Starter
Hmm, pretty sure I did. Now i'm second guessing myself. The retainer clip did break on removal. I was still able to get the clip back on but it wasn't easy. I ordered a new clip and will install tomorrow.
post #4 of 7 (permalink) Old 09-03-2019, 04:00 AM
407driver's Avatar
some have had this issue if they install a HB for an LML on an LMM. You have to ream out the end of the arm that attaches to the brake pedal lever to get the play required for the brake switch to operate correctly.
407driver is online now
post #5 of 7 (permalink) Old 09-03-2019, 10:56 AM Thread Starter
This went on a LLY. I do plan on replacing the break light switch to eliminate this issue.
post #6 of 7 (permalink) Old 09-03-2019, 10:41 PM
New brake light switch or not, you need to understand how the switch is activated. As mentioned above, the hole in the shaft from the HB needs to be elongated as it fits on the pin from the brake pedal arm. As you press on the pedal, the first little bit, the slop of the pin in the hole, is what activates the light switch. It's awkward to lay under there and see how it works, and if it's working properly.
And, yeah, I mangled the clip and had to put on a new one, too.
2004.5 Silverado 3500 SRW 4x4, D/A (LLY), Ext. Cab, Long Bed
engineer837 aux rad, TxC CAI, LBZ MP, Scangauge II, Nicktane aux filter head, KD lift pump, 2008 PS pump, 2011 hydroboost, Frederico Swaybars, Rancho 9000XL, Torklift StableLoads, BFG AT/KO2, Lance 835 Camper often in the bed.
jake111 is offline
post #7 of 7 (permalink) Old 09-18-2019, 04:45 PM Thread Starter
Sorry for not getting back sooner, so the break lights started working with the old switch. I didn't have to replace it after all.
