Oil pressure switch for lift pump - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 01-21-2020, 05:36 PM Thread Starter
I知 putting together a lift pump/filter setup and I知 working on parts for the power circuit. Does anyone know of a oil pressure sensor that works well for this? I知 hoping there is one with a low enough pressure and will fit without a adapter but just mostly just a low pressure and availability with the normal local stores
05 2500HD 2wd Crew Cab 8 box 2nd owner
Mods:
Intake
Coming mods:
D60 sas
Tunner
(List under construction)
oldchevy4x4 is offline
post #2 of 5 (permalink) Old 01-29-2020, 09:51 AM
jwelder3's Avatar
You may want to look at Kennedy Diesel. My LP kit came with an oil pressure switch. On our LLY's the oil filter mount has extra ports that the switch just threads into, once you remove the plug. Kennedy may sell the switch by itself idk.
05 Silverado 2500HD LT CC 4x4 LLY 280k miles
LBZ mouthpiece. PCV reroute. JK LP. Edge monitor. DP. P/S cooler.
jwelder3 is offline
post #3 of 5 (permalink) Old 01-29-2020, 10:50 AM
LHN...We ARE the Joneses
$20
https://www.kennedydiesel.com/detail.cfm?ID=536
Would need to be wired in to the pump relay correctly.
Hook'em_Horns! is online now
post #4 of 5 (permalink) Old 01-29-2020, 11:23 AM
I have a entire Kennedy switch and harness.... brand new. Message me.
https://www.kennedydiesel.com/detail.cfm?ID=324
AlisoBob is online now
post #5 of 5 (permalink) Old 01-30-2020, 05:12 AM Thread Starter
Alright, I liked the Kennedy harness setup but it didn稚 think to look if they sell the switch by itself. I thought about using the whole harness but I couldn稚 bring myself to justify the extra cost just to get the nice package and the prime at start up feature.
Mods:
Intake
Coming mods:
D60 sas
Tunner
