Maf - Chevy and GMC Duramax Diesel Forum
 2Likes
  • 1 Post By Wildmanben
  • 1 Post By AxysAssault
post #1 of 6 (permalink) Old 07-14-2017, 05:16 PM Thread Starter
Wildmanben's Avatar
Maf
Is there any difference between lbz and lly MAF sensor? I put a lbz cai and turbo mouthpiece on my lly, got a p0101 MAF code, maybe just come incidence but happened soon after the intake install
Sent from my SM-G900W8 using Tapatalk
2005 LLY crew cab short box,
6" Rough Country lift,
EGR deleted PCV Re-routed
LBZ CAI into LBZ turbo mouthpiece
4" Straight pipe
EFI live by Mitch Cooper
Wildmanben is offline
post #2 of 6 (permalink) Old 07-14-2017, 05:54 PM
redneckcowboy28's Avatar
I believe it has to do with the bigger cai piping. Someone please correct me if I'm wrong. May need to retune for the change in size of pipe.
05 Crew Cab 2500HD Duramax, 6" Rancho lift, 33X13.00R18 Nitto Terra Grapplers, Banks Bundle (only using #3 setting with the stock transmission), 4" downpipe, LBZ mouthpiece, straight piped!
redneckcowboy28 is offline
post #3 of 6 (permalink) Old 07-14-2017, 06:41 PM Thread Starter
Wildmanben's Avatar
Ah okay, how does one re tune the MAF? Also I cleaned it with cleaner and the truck responds better now but still blowing that code.
4" Straight pipe
post #4 of 6 (permalink) Old 07-14-2017, 06:44 PM Thread Starter
Wildmanben's Avatar
Ah OK, found another thread about it. Apparently it does need a re calibration through efi live. So I'll have to get that done
redneckcowboy28 likes this.
4" Straight pipe
post #5 of 6 (permalink) Old 07-13-2019, 06:24 PM
I had the same problem and if you want a quick fix you can just get a piece of 4 inch PVC amount the math on it just get like a 4in length and then collar it to accept your open filter. I had the p0101 and a real loss of power. Put the collar on and everything came back to life and drop the check engine light
Steven686 is offline
post #6 of 6 (permalink) Old 07-23-2019, 10:43 AM
EFI tuning required for the increased volume of air.
Sent from my LG-H831 using Tapatalk
mizterwizard likes this.
"Stinky Pig"
2003 Sierra 2500 Crew 4x4–Charcoal Grey Metallic
325k kms and counting
LLY Head swap
LBZ full intake w/MP
Flo-Pro Downpipe
4" Straight pipe
EGR delete
PCV Re-route
EFI Live (E. Stock/30HP/60HP Tow/high idle/No start)
Edge CTS2 with EGT
AxysAssault is online now
