LBZ pass fuel leak - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 09-22-2019, 10:53 PM Thread Starter
LBZ pass fuel leak
just did head gaskets, arp studs, cp3, water pump, etc. put everything back together and she fired right up. After a few minutes I get a fuel leak on the pass side lower valve cover to head gasket. It appears to be coming from the gasket. i can not see a drip from above or any runs. i have checked the return lines, the filter is not the issue as i moved it of to the side. iíve taken the injectors out, valves covers have come off and started it. i canít see any leaks on the injectors with the valve covers off. i canít see anything wet in the valley and itís not coming down off the bell housing. I checked the injectors and they seem good, new copper gaskets, i believe the metal lines are all correct .... I am at a loss!!!!!! any thoughts?
2006 LBZ
Sicmaro is offline
post #2 of 3 (permalink) Old 09-23-2019, 01:38 AM
mizterwizard's Avatar
Clean and dry everything as best you can. Then spray powder on everything. Use something like athlete's foot spray so that it will stick to the parts. Start the engine and run it for only a few seconds. Go looking for the place where the powder is stained. Of course the valve covers should be in place when you do this.
Don't be surprised if fuel is shooting from one place to another and fooling you as to its source.
mizterwizard is offline
post #3 of 3 (permalink) Old 09-23-2019, 02:13 PM Thread Starter
thanks, sry can we move this to the lbz forum..... fat fingers on my phone.
2006 LBZ
Sicmaro is offline
