06 ECSB 4x4 U joint - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 15 (permalink) Old 09-28-2019, 05:59 PM Thread Starter
06 ECSB 4x4 U joint
After 3 trips to advance, an amazon order and a few hours of internet research, I have no idea what U joints are for my truck. Can someone please help?!?!?
2006 ECSB 4x4 one piece steel driveshaft. Looking for the u joint at the rear axle as well as the one at the slip yoke end.
Sent from my SM-G977U using Tapatalk
06 ECSB LBZ. Edge evolution, AirDog2 165, rear air bags, Transflow aux fuel tank, brush guard, headache rack
bam5128 is offline
post #2 of 15 (permalink) Old 09-29-2019, 06:23 PM
beardedlbzguy's Avatar
Have you checked DMAXSTORE.COM? They have all kinds of goodies for our trucks.
As for me, I've got a trustworthy guy that works at the local O'Reillys and he just looked up the numbers in the Spicer book and that's what I went with.
Sent from my SM-G950U using Tapatalk
2006 Silverado 2500HD CCSB
345k+
Painted Stock wheels
beardedlbzguy is offline
post #3 of 15 (permalink) Old 09-30-2019, 06:37 AM
HWI
HWI's Avatar
Spicer 1410 non-greasable is what I go with.
06 LBZ CCSB
With some stuff.
HWI is offline
post #4 of 15 (permalink) Old 09-30-2019, 06:44 AM Thread Starter
May I ask your reasoning for non greasable? I'm used to hitting my front end every 3000 miles or so and always greasing my vehicle in the marine corps so I figured it would be worth the small extra hassle.
bam5128 is offline
post #5 of 15 (permalink) Old 09-30-2019, 06:48 AM Thread Starter
Additionally, I believe the 1410 may be the wrong size for mine. It shows 1.2" diameter and my u joint caps are ~1 3/8"
bam5128 is offline
post #6 of 15 (permalink) Old 09-30-2019, 07:43 AM
HWI
HWI's Avatar
I grease the front end every oil change, but it still seems like the non-greasables last longer. From what I have read on the forums and Facebook groups it seem like most people have the same experience.
I would have thought your truck would have the same yoke and driveshaft as mine, but I could be wrong.
bam5128 likes this.
06 LBZ CCSB
With some stuff.
HWI is offline
post #7 of 15 (permalink) Old 09-30-2019, 07:49 AM
Unless you have a different driveshaft than OE it should fit. '01-'07 Spicer 1410 greaseable or not.
345k+
post #8 of 15 (permalink) Old 09-30-2019, 07:54 AM Thread Starter
I don't have any reason to think it's aftermarket. I bought it from a guy I knew in September 2017. It's the steel shaft (covered in rust). The u joint caps are about 1 3/8" in diameter where as the 1410 is about 1 1/8" in diameter. Idk if the PO had special requests from the factory (wouldn't surprise me knowing how he is) or if that's just what they used for that particular combo (ECSB 4X4 WT)
bam5128 is offline
post #9 of 15 (permalink) Old 09-30-2019, 08:05 AM
HWI
HWI's Avatar
I could be wrong, but I thought all the OEM driveshafts were aluminum, I know mine is.
06 LBZ CCSB
With some stuff.
HWI is offline
post #10 of 15 (permalink) Old 09-30-2019, 08:53 AM
I concur with the non greaseable Spicer. Just put one on last weekend.
Granny driving my one owner 07' GMC 2500HD GFX. 100% original right down to the brakes. Only upgrade EGR delete and EFI LIVE tow tune.
07GFX is offline
