P0401 and P0230 codes - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 14 (permalink) Old 11-25-2019, 08:52 AM Thread Starter
68Ss's Avatar
Yesterday I was leaving Jacksonville and when I went to clear my codes I had a new one. The P0230. I normally carry the other due to the blocker plate. I googled and I searched here on the p0230 code. Not much info unless I missed it. Would the blocker be causing this? It just started with that code.
2007 2500 CCSB /16 X 8 Mickey Thompson Classic / 285x75x16 Cooper ATP / PCV Reroute/Alligator trans cooler hoses / Merchant Automotive pump rub / EDGE CTS2 / Diamond Eye 5" exhaust / Bilstein 5100 shocks
Toby
68Ss is offline
post #2 of 14 (permalink) Old 11-25-2019, 08:59 AM
Former GM Tech and parts
DMAXfirefighter's Avatar
The P0230 code is Fuel Pump Relay Control Circuit, would not be due to the blocker plate. An electrical issue somewhere, but I'm not much help other than that for you right now, sorry.
John Deere Service Manager
DMAXfirefighter is offline
post #3 of 14 (permalink) Old 11-25-2019, 09:02 AM Thread Starter
68Ss's Avatar
I knew that part but reading on here it is also in a bunch of codes that you can get with the egr.
68Ss is offline
post #4 of 14 (permalink) Old 11-26-2019, 02:34 AM Thread Starter
68Ss's Avatar
Ttt
68Ss is offline
post #5 of 14 (permalink) Old 11-26-2019, 03:24 PM Thread Starter
68Ss's Avatar
A little more info. I just change the fuel filter and rebuilt the fuel filter head. I still have the code. I am checking the codes with an edge cts. I checked the codes and the p0230 was there. I cleared codes and turned the truck off. Turned the key on and checked codes and boom the p0230 was there NO CEL. So I am thinking this is more electrical than actual fuel pressure.
68Ss is offline
post #6 of 14 (permalink) Old 11-29-2019, 04:36 AM Thread Starter
68Ss's Avatar
I can not get the code to reset. I even disconnected the batteries for 30 min.
68Ss is offline
post #7 of 14 (permalink) Old 12-02-2019, 09:47 AM
One thing to think about-these trucks don't have an electric fuel pump. If the code will not go away when trying to reset it, that's means it is an active issue and won't go away until it is repaired. Might not hurt to pull the fuse block cover and check the wiring under the fuse block, see if you have a wiring issue going on underneath it
post #8 of 14 (permalink) Old 12-02-2019, 11:08 AM
HWI
HWI's Avatar
I thought the fuel pump codes were only for cab and chassis models that have dual fuel tanks. I don't understand what it could be referring to on a Duramax with only 1 tank, not like we have a fuel pump.
06 LBZ CCSB
With some stuff.
HWI is online now
post #9 of 14 (permalink) Old 12-02-2019, 11:50 AM
Donít believe any of them would run without a fuel pump?
Sent from my iPad using Tapatalk Pro
2007.5 Chevrolet 2500HD CC SRW 6.6 LMM 190,000 miles. Bought new
New up-pipe, 3Ē downpipe, cold air intake, cold and hot side tubes, Transgo Junior kit, Allison deep pan and filter kit, Moog tie rod upgrade
2015.5 Chevrolet 3500HD CC DRW 6.6 LML 108,000 miles Bought with 98,000 miles
Stock
Toolbox58 is offline
post #10 of 14 (permalink) Old 12-02-2019, 11:57 AM
HWI
HWI's Avatar
Maybe you are thinking of injection pump? Your normal non-cab and chassis Duramax definitely does not have a fuel pump.
Toolbox58 likes this.
06 LBZ CCSB
With some stuff.
HWI is online now
