P0087 lbz stock fuel system low pressure - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By DMAXfirefighter
post #1 of 9 (permalink) Old 12-04-2019, 08:47 PM Thread Starter
OK I have a 2006 lbz It has 220,000 miles I had injectors tested on both balance and returns rates both fine head CP three tested fine and have fresh fuel filter on have PPE race fuel plug in and whenever I turn the tuneup and sometimes on stock when I get into it hard I will lose pressure now the last things I’ve gotten down to is the FPR or bad Lines has anybody had similar problems ideas?
Dillonlbz is offline
post #2 of 9 (permalink) Old 12-05-2019, 05:09 AM
407driver's Avatar
several possible causes.
1.Leaky fuel filter head
2, leaky braided fuel lines (drivers side rear of engine, below driver side and possibly on top of the fuel tank
3. cracked fuel pickup in fuel tank.
This thread describes a fix for a known problem.
https://www.duramaxforum.com/forum/d...tml#post775709
and this thread has some good information for you as well:
https://www.duramaxforum.com/forum/m...ew-owners.html
407driver is online now
post #3 of 9 (permalink) Old 12-05-2019, 06:41 AM
John Deere Parts guy
DMAXfirefighter's Avatar
I know you say the return rates are good, but I would venture to guess this- under high demand, higher throttle, higher pressure, the injectors are returning too much fuel and making the pressure drop. Yes, at idle or cranking the return rates are in spec, but that's not a high-demand situation. I have the same situation on my LBZ I have now, it has 290k on it and every day driving or most towing its fine. But with my LB7 on the trailer (set up for sled pulling and weighing 8000 pounds) if I try to push it too hard, the rail pressure cant keep up. I've worked on the same situation with other trucks, and the fix was injectors-they were just returning too much fuel under high demand.
407driver likes this.
John Deere Service Manager
DMAXfirefighter is online now
post #4 of 9 (permalink) Old 12-05-2019, 07:10 AM Thread Starter
Yes but i dont have this problem with towing I hardly ever tow with the truck and i had a mechanic look at it and he says that if its not fuel filter wich it wasnt it has to be fpr or possibly lines
post #5 of 9 (permalink) Old 12-05-2019, 11:24 AM Thread Starter
And also there arent any visible leaks that i can see since putting the filter on last night it starts much better and will hold 26 ksi for about 10 seconds even on high tune and all of a sudden it just dips and slows down
post #6 of 9 (permalink) Old 12-05-2019, 11:53 AM
Ok, so you're not towing. But if it holds rail and then drops off under heavy or wide-open-throttle, its not keeping up under high demand. So its either the tune is too large for the cp3 to keep up without a lift pump, or the injectors are bypassing and returning too much fuel under higher demand and making the rail pressure fall off. That's where I am, only I'm not on a big tune. My truck will run fine if I'm 3/4 throttle or below- actual rail pressure is with desired as long as I'm not demanding too much. If I go over 3/4 throttle for more than a few seconds, the rail pressure starts to fall off
post #7 of 9 (permalink) Old 12-05-2019, 10:50 PM Thread Starter
Update put a lift pump tonight held pressure for exactly one pull then went into limp mode any time i tried giving it fuel it smoked like a fright train and wouldn’t go any faster and threw a p0101 and p0102 if that helps
post #8 of 9 (permalink) Old 12-06-2019, 06:03 AM
P0101 Mass Air Flow Sensor Performance and P0102 Mass Air Flow Sensor Circuit Low Frequency so clean the MAF, clear the codes and see what it does after that
post #9 of 9 (permalink) Old 12-08-2019, 11:49 AM Thread Starter
Cleaned it starts fine idles fine but as soon as it goes in drive it lopes hard and blows whiteish smoke doesnt make any noises
