07 LBZ wonít start. Oil number 4 cylinder - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 12-06-2019, 10:27 PM Thread Starter
Bought a 07 LBZ with engine trouble. It was hard to crank. I charged the batteries and removed all of the glow plugs. Number 4 cylinder glow plug was soaked in oil. When I turn it over oil shoots out of the glow plug hole on that cylinder. There isnít any blow by coming out of oil filler tube. I removed the valve cover and the valves are all up and working. I pulled off the belt to make sure crank wasnít loose. Iím not sure what to check next. Any ideas.
HVAC_Vol is offline
post #2 of 6 (permalink) Old 12-07-2019, 09:46 AM
Compression.
mray is offline
post #3 of 6 (permalink) Old 12-07-2019, 10:00 AM
DIRTEEMAX's Avatar
Sounds like my friends LBZ with a cracked piston.
2002 2500HD 4x4 ccsb
EFI live Idaho Rob
LBZ CP3 and regulator
4'' lift
Ultra Predators
Toyo RT's
WHEN GUNS ARE OUTLAWED I'LL BE THE OUTLAW !!
DIRTEEMAX is offline
post #4 of 6 (permalink) Old 12-07-2019, 12:42 PM Thread Starter
Thatís my next step.
HVAC_Vol is offline
post #5 of 6 (permalink) Old 12-07-2019, 12:43 PM Thread Starter
Did he have any blow by coming out filler tube? I talked to a local diesel mechanic and he said he had one do the same thing and it was a cracked piston.
HVAC_Vol is offline
post #6 of 6 (permalink) Old 12-13-2019, 09:41 AM
DIRTEEMAX's Avatar
Sorry about the delay replying to you but . Im not usre if he did or not at first we thought bad injector until I smelled the smoke once I got a whiff I knew it was catastrophic. $9500 for an engine installed from the dealer with a warranty
EFI live Idaho Rob
4'' lift
Ultra Predators
Toyo RT's
