coolent system - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 01-05-2020, 08:48 PM Thread Starter
coolent system
i have a 06 lbz and the truck keeps building pressure in the antifreeze reservoir tank and once it builds up enough pressure it boils out the over flow hose. we have changed the thermostats. was told that it could be the water pump or the head gaskets.
thennis is offline
post #2 of 6 (permalink) Old 01-06-2020, 01:10 AM
LHN...We ARE the Joneses
After sitting overnight, or several days, is the top rad hose firm? Or can you squeeze it flat with minimal effort?
Is the EGR still intact?
Hook'em_Horns! is offline
post #3 of 6 (permalink) Old 01-06-2020, 09:54 AM
LeRoy's Avatar
Check the firmness of the radiator hose the next morning after the truck ran. If it is rock hard, that is an indicator of a bad head gasket.
2003 Chevy 2500HD LB7 white extended cab long bed
PPE Hot, FASS 150, 5" pipe, boost valve, 3" intake elbow, sleeves, Insight CTS2, and winterized
34x12 Mickey Thompson MTZ's on 17x9 Pro Comp's
Initial Success or Total Failure
LeRoy is offline
post #4 of 6 (permalink) Old 01-06-2020, 09:56 AM
LeRoy's Avatar
When my water pump was bad, my truck would randomly piss out coolant. I never had any pressure in the tank. But my truck is an lb7, might be different for you.
LeRoy is offline
post #5 of 6 (permalink) Old 01-06-2020, 11:23 AM
Location for the coolant temp sensor for a 2015 duramax
Randy Griffin is offline
post #6 of 6 (permalink) Old 01-06-2020, 12:06 PM
They're all next to the T-stats, up top. Easy access.
