P0206 P0207 but why!? - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 01-21-2020, 04:00 PM Thread Starter
2006 regular cab LBZ . So I was plowing this weekend and I pushed up to the bank and the truck gave a shutter. I backed up then it was misfiring threw two codes p0206 and p0207 which I know is low voltage on 6+7 injectors but I can clear it and truck will idle fine when I go to give it fuel it’ll get up a little over 1000 rpm and engine light comes back on and shutter and misfire occur. What could it be? I don’t think it’s injectors cause if I clear the code it will idle normal and run smooth and two injectors going bad at the same time doesn’t seem right. Could it be chafed wires? Or maybe a bad ECM? Anyone else run into something like this? Thanks!
-Luke
Luke Myhaver is offline
post #2 of 4 (permalink) Old 01-21-2020, 07:35 PM
407driver's Avatar
Have you looked at the connectors on the two injectors? Often times low voltage is either a chaffed wire (could be at injector or ECM) or a bad connection at the injector.
try removing removing the connectors, cleaning the contacts on both the connector and the injector and use a bit of Di-electric grease when putting them back on.
407driver is offline
post #3 of 4 (permalink) Old 01-22-2020, 02:59 PM Thread Starter
If was chaffed wires right off main harness plug every time I read that the motor would move and it was short out on the harness tie down. All fixed runs great
post #4 of 4 (permalink) Old 01-24-2020, 12:12 PM
Thanks for the update.
mray is offline
