Starter inoperative-- 6 speed-- after a jump start - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 06-21-2012, 02:29 PM Thread Starter
DuramaxForum Guru
jc1843's Avatar
GM has issued a TSB on the problem.
https://www.duramaxforum.com/forum/tr...m-shorted.html
jc1843 is offline
post #2 of 6 (permalink) Old 06-21-2012, 02:47 PM
Coffee addict
ty_LBZ's Avatar
Good to know! Thanks!
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa muffler. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts. Curt class 5 hitch.
10/30/14- cracked piston
03/14/15-Back from the dead
ty_LBZ is offline
post #3 of 6 (permalink) Old 06-26-2012, 12:53 PM
Do not ground welders,battery chargers,electrostatic painters or any other equipment to the heatsink.Disconnect the 80 way connector from the TCM when electrically welding etc. to the vehicle.
Who in the hell would ground to the TCM case?! Shouldn't be a TSB, should be a way to go Dumba$$.. pay for a new one!!
Black6spdZ is offline
post #4 of 6 (permalink) Old 10-05-2012, 10:20 AM
Where is the TCM? I know where the computer (ECM?) is but well I guess I have not looked. I have been an LBZ owner for about 1.5 weeks now.
ratnfested is offline
post #5 of 6 (permalink) Old 10-12-2014, 10:56 PM
TCM is the module mounted to the back, driver side, upper half of the radiator shroud on the LBZ. ECM is just down from the battery on the driver side.
Matt750 is offline
post #6 of 6 (permalink) Old 05-16-2017, 07:27 PM
dvierra86's Avatar
My friend had the same issue after hooking up cables backwards. It fried a internal circuit in the underwood fuse box
dvierra86 is offline
