Powertrain humming under load at high speed - Page 2 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #11 of 14 (permalink) Old 02-07-2016, 08:16 PM
auzzy89's Avatar
Originally Posted by SamBroom View Post
I took another look today and did notice something I was wondering about, the shaft is two peices and at the split, it goes through a bearing loop that is bolted to the frame. I can wiggle the shaft pretty substantially inside that loop. Potentially my problem?
I think that could be your issue. I'll look into it some more. Sadly I don't have a two piece drive shaft so I know that isn't my problem.
06 2500HD CCSB: EFI Live by duramaxtuner, Blocker plate, Airdog II 165, Banks 4" Exhaust, Banks Intake, 6" RCD lift
auzzy89 is offline
post #12 of 14 (permalink) Old 02-08-2016, 01:19 PM Thread Starter
SOLVED. After taking a ride with a mechanic and getting his confirmation that the issue was definitly in the driveline, i took it home and pulled down the shaft to inspect it. Unfortunately, I can't tell you exactly what the issue was, because I tackled two together. First, the front u joint had an obviously bad bearing. It was catching at a certain point and took some effort to push through the rough spot. Second, the rubber mounthe around the carrier bearing was SHOT. I replaced both the carrier bearing and the front u joint. And now it rides like a dream. I attached some pics of the hashed carrier bearing.
RLLBZ likes this.
SamBroom is offline
post #13 of 14 (permalink) Old 02-08-2016, 03:18 PM
Passin Thru's Avatar
GOSH!
Delete Delete Delete
06, EDGE tuner, Parker Power Steering and Transmission cooler Hoses, Airride, 100 gal aux tank, Reese 5th wheel and gooseneck hitch, 12K 22ft boattail w/ramps, 20 ft stock trailer, 19 ft bassboat, 2004 Northwood Arctic Fox TT GCVW 18.9K 2.4 million miles on Large Cars
My other car is a Peterbilt 379
Vote for me My platform is "Because I said so!"
Passin Thru is offline
post #14 of 14 (permalink) Old 02-08-2016, 03:24 PM
RLLBZ's Avatar
Nice work!
2007 GMC 2500 SLT Classic
|Airbox Mod|PCV Reroute|Nictane FFA|AD2-150 w/ Bean's Sump|SDP EGR Delete|MBRP 4" Exhaust & DP|EFI-Live|TransGo Jr|Pump Rub Fix
RLLBZ is offline
