Noises - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 10-03-2018, 12:19 PM Thread Starter
auzzy89's Avatar
Noises
My stock 2006 has some noises that I'm trying to track down so I can hopefully get rid of them. I'm new to the Baltimore area and I would prefer to do it myself. One of the noises sounds like an exhaust leak but I haven't been able to find it. I've been looking and feeling but no luck. Another noise is a hum/vibration that only occurs at about 70mph. And the final noise is a clunk when starting and stopping. I'm wondering if anyone in my area might have a little bit of time to help me identify the problem. I'll have good and beer (maybe some bourbon).... Any help or advice is greatly appreciated.
Sent from my SM-G965U using Tapatalk
06 2500HD CCSB: EFI Live by duramaxtuner, Blocker plate, Airdog II 165, Banks 4" Exhaust, Banks Intake, 6" RCD lift
auzzy89 is offline
post #2 of 7 (permalink) Old 10-06-2018, 05:04 PM
beardedlbzguy's Avatar
As far as the noise at start and stop, I'd check the u joints. Mine did that when I bought it and thought it was rear bushings but eventually my u joint started chirping and after I changed them it stopped making that noise.
Sent from my SM-G950U using Tapatalk
2006 Silverado 2500HD CCSB
345k+
Painted Stock wheels
beardedlbzguy is online now
post #3 of 7 (permalink) Old 10-06-2018, 06:00 PM Thread Starter
auzzy89's Avatar
I'll take a look at them. Thank you for the tip.
auzzy89 is offline
post #4 of 7 (permalink) Old 10-09-2018, 06:16 AM
Dukemax's Avatar
Injector knock can sound like an exhaust leak.
06 LBZ, 285 General Grabber AT2
EFI Live by Farmtuned, egr blocked, cat delete, pioneer avh-x4700bs
Dukemax is offline
post #5 of 7 (permalink) Old 10-09-2018, 06:52 AM Thread Starter
auzzy89's Avatar
How would I diagnose that? And is there a fix? Thank you for the input.
auzzy89 is offline
post #6 of 7 (permalink) Old 10-09-2018, 08:20 PM
SST 1953's Avatar
Is the exhaust noise you're describing more of a tick? If it is a tick, try a different oil. My LBZ had a very noticeable tick running Rotella, mostly gone running Delvac. The start stop is either a u joint or the tranny yoke. Good luck!
2016 CCLB Dually LML
SOLD: 2007 CCSB LBZ.
69 Camaro S/ST-S/Gas
SST 1953 is offline
post #7 of 7 (permalink) Old 10-10-2018, 12:54 PM
Dukemax's Avatar
I had a similar tick/knock sound, thought it was exhaust. Checked several things manifold, uppipe, you name it. Finally did the injector cleaning that Iíve been wanting to do for sometime. And while running truck for the cleaning procedure the noise went away. I have since added Kennedy lift pump and keep additive to it and noise still gone.
Dukemax is offline
