LBZ Shaking and TC not locking up on Highway while towing - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 03-28-2019, 07:24 AM Thread Starter
Rumpeltiltskin's Avatar
Truck is in Signature.
I was pulling my large 5th wheel camper (Approx 20,000 lbs gross weight truck and camper) to and from Kansas this week. Approx 500 miles round trip. Between 65 and 70 mph going up hill it would begin to shake if I was in 5th or 6th gear. If i hammered the throttle or "manually" shifted and made it downshift to 4th gear it would stop and pull like normal. I got the p0087 low rail pressure code a couple times and only once I got a p0700(I think) trans mil light and also a (forgot the number 2653??) turbo boost actuator A code at the same time. After all of this happened the torque converter wouldn't lock up anymore which in turn caused the trans fluid to get hot. I pulled over when the trans temp got to 230 degrees and let everything cool down while idling for about an hour. I shut it off to reset the computer(s) That fixed the torque converter problem but the shaking continued if I didn't shift down or drive slower or faster than 65-70 mph range. I monitored desired fuel rail psi against actual fuel rail psi on the CTS and it was right on the money which leads me to believe it isn't a fuel problem, however it is probably time to change the filters on the air dog anyway.
Transfer case just replaced with Kodiak truck unit. I also updated to the nickel slip yoke and new u joint and lubed the splines back at the carrier bearing as suggested by Kodiak truck. All other u joints on rear driveshaft were replaced less than 5000 miles ago. I rotated the tires right before we left but i did not re balance them.
I think I will replace the fuel filters and re balance all 4 tires and try again but I think it may be internal transmission issues since it only does it in 5th and 6th gear. Maybe a shift solenoid? Maybe torque converter? Trans Computer? Any guidance will be appreciated.
2007 Chevy 2500HD CLASSIC LBZ crew cab long bed LT 4X4 EFI Live by ATP...stock, heavy tow with brake, light tow with brake, street/economy, FUN 120HP ...MBRP 4" downpipe back with muffler, Edge CTS for gauges and edge expandable EGT probe, ppe frprv shim kit, egr race plate ADII 165, Transgo Jr. ,ATP tie rod sleeves, Cognito pitman and idler arm braces, Kodiak Truck transfer case, , 165k miles(and counting), 265/75/16 tires pyo wheels, B&W hitch with companion, prodigy P3, husky liners front and back, Lund running boards,
Rumpeltiltskin is offline
post #2 of 4 (permalink) Old 03-29-2019, 07:33 AM Thread Starter
Changed both air dog fuel filters, they only had 11000 miles on them but they were changed a year and a half ago. Drives fine unloaded. Anybody have any ideas?
post #3 of 4 (permalink) Old 08-13-2019, 04:02 PM Thread Starter
Just pulled camper as well as a small 16ft bumper pull with a polaris ranger and a 4 wheeler behind the camper. Up and down the mountains and there was no shaking or torque converter problems this time. HOWEVER I'm still getting the P0087 low fuel rail psi code. It will only set the code if I am in 5th or 6th gear. I monitored desired vs actual again and in 5th gear if it demanded 23k it would only go to about 19 or 20k. If I caught it in time and forced it to shift down into 4th it would get plenty of fuel and not set the code. Both air dog filters were changed less than 1000 miles ago but the factory filter hasn't been changed in about 50k miles. IN THEORY with the air dog filters the factory filter shouldn't ever get anything in it. I know some guys even delete the whole factory unit all together. I think I will try to change the factory fuel filter next but if that doesn't fix it what could it be??? Cp3 getting weak???
post #4 of 4 (permalink) Old 08-13-2019, 05:22 PM
HWI
HWI's Avatar
Put a gauge post lift pump and see what pressure your AD is putting out when your actual rail pressure is not meeting desired.
06 LBZ CCSB
MBRP 3" down pipe/4" straight pipe, PPE Xcelerator, FASS 150, Beans sump, deleted, pump rub fix
Zone 6" lift, Kryptonite tie rods
HWI is online now
Similar Threads
Steering shaking while stationary Troponin 11-16 LML Duramax Powertrain 2 12-29-2014 11:06 PM
TC question... Locking up at idle Dmaxster Transmission Shop 4 02-10-2014 04:28 PM
Locking or Non Locking Rear Diff? lynxer 07.5-10 LMM Duramax Powertrain 4 12-13-2011 06:40 AM
tc slow to finish locking up chinaman Transmission Shop 2 01-16-2011 09:22 PM
