Couple of issues - Page 2 - Chevy and GMC Duramax Diesel Forum
 3Likes
post #11 of 15 (permalink) Old 04-08-2019, 04:02 AM Thread Starter
Anyone else have an answer/opinion to this problem?
Could it be related to the transfer and output shaft of electrical??
paulf508 is offline
post #12 of 15 (permalink) Old 04-09-2019, 03:13 AM Thread Starter
Had some work done yesterday power steering pump and rear u-joint. Extremely surprised that the new u-joint made a huge difference as I can go at least 55mph as the service brake system/abs light warning did not come on.
Still no cruise or manual shift select and still seems to be shifting a little strange. This seems to be more of an electrical issue then anything else but I will know better today when I do some highway driving.
paulf508 is offline
post #13 of 15 (permalink) Old 04-10-2019, 04:03 AM Thread Starter
******UPDATE******
Hit the road yesterday and comfortably cruised at 70-75mph without any issues except the cruise and manual shift didn't work.
Stopped at my repair shop and cleared all the codes got back on the road and cruise and manual shift working again!
Conclusion: (as far as I can tell) Bad rear u-joint was vibrating enough to cause the output shaft to move enough to have the speed sensor act abnormal. The only thing I changed mechanically was the transfer case speed sensor and the u-joint.
Knock on wood she will be good for another 100k miles!
paulf508 is offline
post #14 of 15 (permalink) Old 04-10-2019, 05:17 AM Thread Starter
Originally Posted by paulf508 View Post
Brand new to the forum....tons of great info and I am hoping someone can help me out.
'06 2500hd with 401,000mi. Truck has been awesome to me and my family and just keeps on running...love this truck.
A few weeks ago at 40mph my speedo starts bouncing and "Service Brake System" lights up along with the ABS light. Lost cruise control and manual shift.
The speedo bouncing will continue know matter what speed, occasionally it will level out but only for a few seconds and then start to bounce again. This makes the tranny shift back and forth and will sometimes get stuck in 4th gear so I have to pull over, shut off the truck and let it reset. The shifting sequence seems to be more MPH based as well.
Stopped and checked the codes and got a bunch of them but I am guessing they are all related to this issue. The 2 codes that stood out are U0100 ground issue and P2723 Pressure Control Solenoid. I was hoping to see a code for one of the speed sensors!!
Any suggestions/help would be greatly appreciated!
Paul
******UPDATE******
paulf508 is offline
post #15 of 15 (permalink) Old 04-10-2019, 05:39 AM
John Deere Parts guy
DMAXfirefighter's Avatar
******UPDATE******
If the output of the t-case is moving that much, you probably need to check the rear bushing and the bearings in the case. Even with the rear u-joint vibrating, it shouldn't move the output shaft that much.
John Deere Service Manager
DMAXfirefighter is online now
Similar Threads
Couple Issues, any help? n0useforaname Drivetrain 10 02-01-2013 10:06 PM
New truck (to me) with a couple of issues jc8825 07.5-10 LMM Duramax Powertrain 12 04-08-2012 09:39 AM
2011- LML 1400 miles - couple minor issues??? Bill Braskey 11-16 LML Duramax Powertrain 3 01-27-2012 06:06 PM
LMM issues issues issues blaineGMC 2007.5 + (GMT 900) Non Powertrain--New Body Style-- 5 05-17-2010 09:01 AM
Couple of issues c_heskett 01-04.5 LB7 Duramax Powertrain 5 04-07-2007 02:07 PM
