Couple of issues - Chevy and GMC Duramax Diesel Forum
 3Likes
post #1 of 15 (permalink) Old 04-04-2019, 07:01 AM Thread Starter
Exclamation Couple of issues
Brand new to the forum....tons of great info and I am hoping someone can help me out.
'06 2500hd with 401,000mi. Truck has been awesome to me and my family and just keeps on running...love this truck.
A few weeks ago at 40mph my speedo starts bouncing and "Service Brake System" lights up along with the ABS light. Lost cruise control and manual shift.
The speedo bouncing will continue know matter what speed, occasionally it will level out but only for a few seconds and then start to bounce again. This makes the tranny shift back and forth and will sometimes get stuck in 4th gear so I have to pull over, shut off the truck and let it reset. The shifting sequence seems to be more MPH based as well.
Stopped and checked the codes and got a bunch of them but I am guessing they are all related to this issue. The 2 codes that stood out are U0100 ground issue and P2723 Pressure Control Solenoid. I was hoping to see a code for one of the speed sensors!!
Any suggestions/help would be greatly appreciated!
Paul
paulf508 is offline
post #2 of 15 (permalink) Old 04-04-2019, 08:28 AM
Couple of issues
I donít have your truck, but you need to find the speed sensor and check, clean or replace. I think itís on one of the shafts from the transfer case if 4x4.
A lot of times the code you get is caused by something else that doesnít necessarily throw a code. Your transmission code is probably caused by transmission trying to do multiple shifts because of faulty speed sensor. And it may not be sensor but wiring.
paulf508 likes this.
MIkey52 is offline
post #3 of 15 (permalink) Old 04-04-2019, 08:46 AM Thread Starter
Thanks for the feedback and It is 4 wheel drive
I did find the sensor on the transfer case. Going to take that out now.
paulf508 is offline
post #4 of 15 (permalink) Old 04-04-2019, 08:59 AM Thread Starter
Just pulled the speed sensor out of the transfer case. When I disconnected the wires I found the ends wet with transfer case fluid and the inside of the sensor as well. I am guessing this should be dry??
paulf508 is offline
post #5 of 15 (permalink) Old 04-04-2019, 10:51 AM
John Deere Parts guy
DMAXfirefighter's Avatar
Yes, that should be dry. It very well could have cracked and gotten fluid inside it and is affecting the signal coming out of it. Pull the sensor out and be sure it hasn't hit the gear it reads for signal or have a big hairball or something on it. Sounds like you need to replace the sensor, but if the sensor has been hit or it has a hairball on it there may be problems inside the case
John Deere Service Manager
DMAXfirefighter is offline
post #6 of 15 (permalink) Old 04-04-2019, 12:48 PM
Send a message via Yahoo to Gregory J. Weldon
CrazyGreg
You might want to use an inspection mirror and look at the top of the transfer case to look for a small Or Large hole
caused by the oil pump moving too much. There is a repair part available online and you can repair case w/heliarc
weld.
Gregory J. Weldon is offline
post #7 of 15 (permalink) Old 04-04-2019, 01:23 PM
Also, you can put some Dielectric grease in the connector when you put it back together, that will help keep the moisture out.
2019 2500 Silverado Z71 LTZ. God Bless America!
tobyhd02 is offline
post #8 of 15 (permalink) Old 04-05-2019, 03:25 AM Thread Starter
The sensor didn't have any type of hairball or anything else attached to it. It didn't look like it had been hit either. As far as I know it is the original and if that is the case it had 402,000 miles on it!
I installed the new one yesterday but I didn't have a chance to run the truck. I will do that this morning.
paulf508 is offline
post #9 of 15 (permalink) Old 04-05-2019, 08:54 AM Thread Starter
STRIKE 1
Unfortunately the new sensor didn't work unless I have to clear all the codes first!!??
paulf508 is offline
post #10 of 15 (permalink) Old 04-05-2019, 09:06 AM
LHN...We ARE the Joneses
Yes.
When replacing any sensor or module, I like to pull the -neg on the batteries beforehand.
After, a new start up sequence links all the happy family together again.
Hook'em_Horns! is online now
Similar Threads
Couple Issues, any help? n0useforaname Drivetrain 10 02-01-2013 10:06 PM
New truck (to me) with a couple of issues jc8825 07.5-10 LMM Duramax Powertrain 12 04-08-2012 09:39 AM
2011- LML 1400 miles - couple minor issues??? Bill Braskey 11-16 LML Duramax Powertrain 3 01-27-2012 06:06 PM
LMM issues issues issues blaineGMC 2007.5 + (GMT 900) Non Powertrain--New Body Style-- 5 05-17-2010 09:01 AM
Couple of issues c_heskett 01-04.5 LB7 Duramax Powertrain 5 04-07-2007 02:07 PM
