06 Lly TCM - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 04-19-2019, 02:44 PM Thread Starter
06 Lly TCM
Took my truck in to dealership to have TCM flashed, had no communication code , after a day dealership calls says ignition switch is bad, I had recently replaced it and told him the problem remained even after I replaced it, but told him go ahead replace it just because it was already there and maybe I did something when I replaced it ... Next day get another call, this time tells me that there is a circuit broken somewhere that is causing the no communication to TCM, at this time he tells me there was nothing wrong with the ignition switch, that they need to chase electrical see where the problem is.. Hesitant to let them do anything else at this point, but its there it would be hassle to go get it take it someplace else so I say go ahead keep me posted before you get to deep into it.. Today ... Calls tells me the mechanic isnt getting 12 volt reading from my underhood fusebox that it needs replaced .. Wth !!... I drove it there everything worked ... What would you do ???
JD0867 is offline
post #2 of 11 (permalink) Old 04-19-2019, 10:43 PM
It's obvious what they're doing - they're ROBBING YOU! The correct sequence is to figure out what is causing the problem, prove that you are right, then apply the fix, and if necessary install new parts. Your dealer started at the 'install new parts' end. Now that they have been proven stupid and incompetent, they want your to pay more, pay more, pay more.
Tell them to refund they money you have already paid because THEY FAILED TO FIX THE PROBLEM!
Ron Nielson
Ron Nielson is offline
post #3 of 11 (permalink) Old 04-20-2019, 03:28 AM
SilverGorillaLML's Avatar
Have it towed somewhere else. Preferably a diesel performance shop. They're throwing parts at it wanting to replace the entire fuse box.
Nic
2011 GMC Sierra 2500 cc/sb LML Quicksilver
Has some stuff to make it go fast and blow up sooner.
2 Banks performance dpf's, 2.5 egr coolers, 3 Def tanks filled with meth, custom hot air intake, snail mod,
garden hose ran from fass, 16 John deere injectors, 22x16-378 forces, and like sooo many stickers brah
Wiles Diesel Performance
Woodstock, Va
post #4 of 11 (permalink) Old 04-20-2019, 05:16 AM
Black HD's Avatar
The guy working on your truck isn't a mechanic, he's a parts replacer. Have it towed to somewhere they can diagnose the problem. Good luck.
2005 Toyota Tacoma DC 4x4 4.0L TRD Off-Road
2008 Yamaha Zuma YW 50
2015 GMC 2500 Denali HD 4x4 Duramax/Allison Black on Black
2016 Grand Design Momentum M-Class 350M Toy Hauler
Black HD is offline
post #5 of 11 (permalink) Old 04-20-2019, 09:31 PM Thread Starter
Agreed...parts replacer .. Seem to be guessing .. At my expense. Going to find diesel performace shop Monday
JD0867 is offline
post #6 of 11 (permalink) Old 04-20-2019, 10:05 PM
Where are you located at?
Nic
Woodstock, Va
post #7 of 11 (permalink) Old 04-20-2019, 11:51 PM Thread Starter
Fort Worth
JD0867 is offline
post #8 of 11 (permalink) Old 04-21-2019, 09:36 AM
Texas is so big..
How far are you from Josh H at top notch garage? Hes in van texas
Nic
Woodstock, Va
post #9 of 11 (permalink) Old 04-21-2019, 10:03 AM
LHN...We ARE the Joneses
Close by for TX.....3.5 hrs.....
Hook'em_Horns! is offline
post #10 of 11 (permalink) Old 04-22-2019, 12:31 PM Thread Starter
Lol !
JD0867 is offline
Similar Threads
New TCM - Is my autocal locked to the old TCM? HomeR365 EFI Live 2 08-17-2017 06:02 PM
Where to get a new TCM 06 LBZ chevygirl6.6 Transmission Shop 4 06-25-2015 12:32 PM
06 Duramax Loss comunication with TCM code u0101 dmax3444 06-07 LBZ & LLY Duramax Powertrain 6 06-25-2013 04:43 AM
