Allison 100 Trans Pan Leaking - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 06-29-2019, 09:20 AM Thread Starter
Anyone ever have a problem with the trans pan gasket leaking? Ive changed the gasket 3 times and it still leak in the rear of the pan. All the bolts are torqued to spec (18 ft lbs). Any ideas what options are available to stop it from leaking?
navman28 is offline
post #2 of 7 (permalink) Old 06-29-2019, 09:28 AM
Location: we live in a high mountain valley in the hi country of northern arizona
how positive are you that the leakage is at the pan gasket? Oil (especially tranny oil) is sneaky. Can fool you. In both my aviation and automotive work, I have found the dye kits to be the fastest way to confirm exactly WHERE an oil leak originates. There are several on the market - they sell you a pair of special goggles, and little bottles of dye you dump into whatever is leaking oil. And a special flash-light. In a dark area, the area where the leak is actually coming from just literally JUMPS out at you.
6686L is offline
post #3 of 7 (permalink) Old 06-29-2019, 12:49 PM
If it is truly the trans gasket that is leaking, a new gasket is called for under the circumstances. Clean the pan and transmission rails (where the gasket touches) thoroughly.
Ron Nielson
Ron Nielson is offline
post #4 of 7 (permalink) Old 06-29-2019, 03:00 PM
Armus's Avatar
Check for nicks / deep scratches on the mating surfaces contacted by the gasket.
DPF/SCR technology summarized in three words: It doesn't work.
Armus is offline
post #5 of 7 (permalink) Old 06-29-2019, 04:50 PM
Back in the old days before drain plugs, we would take a pair of hammers and check to see that the bolt holes were flat to ensure proper seating of the gaskets.
On the trans leaking from the rear, I think there was a thread a while back where the connector plug or selector seal was leaking and running down the gasket and making itself known by the fluid found at the rear of the pan. Might start checking the sides of the trans to see if there is anything that looks "wet or damp".
2004.5 Silver Birch Metallic GMC K2500HD
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
jlawles2 is offline
post #6 of 7 (permalink) Old 06-29-2019, 11:08 PM
DuramaxForum Guru
1TRIKHD's Avatar
Location: Where Loggers do it better in the Woods. PNW Son!
I agree with this. On my lbz I thought I had a gasket leak at the rear of my pan. End up being the main harness, where trans fluid would leak through where the wires came from the inside of the pan to the outside and spread around where the pan gasket was. Replaced that harness and all was good.
Sent from my VS988 using Tapatalk
2006 Victory Red CCLB LT3 LBZ
Tuned by Blake Crenshaw
SDP Fully Built Trans w/ Billet Goerend G Converter
S472 SX-E.87/1.0ar sitting on a Wagler street intake W/ a twisted pedestal
Stock Sticks
Special thanks to Scott with Screaming Diesel Performance
Blake with Unleashed Duramax tuning
1TRIKHD is offline
post #7 of 7 (permalink) Old 07-21-2019, 08:04 AM Thread Starter
Turns out it was the shift shaft seal again. The stealership had already replaced it 3 times along with a new shift shaft. Took it to a family friends shop and they got it in correctly and no leaks so far.
navman28 is offline
