Loud click on take off from stop - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 08-07-2019, 08:16 AM Thread Starter
Hello all.
I have a 2006 2500 HD 4WD Allison Duramax that is experiencing a loud click that is coming from underneath the truck, unable to determine if from the trans, transfer case, rear end or driveshaft. It doesn't do it all the time and appears to do it more when going straight, or turning left. Sometimes it is louder than other times it happens. the truck has about 170K miles on it. Everything underneath visually looks ok, all fluids are fine. No vibration at speed or any other abnormalities, just the loud click when accelerating from a stop.
Thanks
bluemaruder001 is offline
post #2 of 14 (permalink) Old 08-07-2019, 08:23 AM
Had/have a similar issue with my 06 ECSB. Have you checked/greased the driveshaft splines at the t-case? That seemed to take care of one noise I had but I still have another click/pop noise when taking off from a stop.
The one that remains seems to come from somewhere in the cab area or front of the truck.
Sent from my SM-G977U using Tapatalk
06 ECSB LBZ. Edge evolution, AirDog2 165, rear air bags, Transflow aux fuel tank, brush guard, headache rack
bam5128 is offline
post #3 of 14 (permalink) Old 08-07-2019, 12:08 PM
MiamiMax's Avatar
I would check the motor mounts, if they are cracked, you probably wont see them, but they do that cling noise.
2016 Z71 2500HD w/RC Leveling on 305/55/20 XD Misfits
No engine mods... yet. Hauls a 20' Enclosed Motorcycle Trailer.
Ssgt. USMC 85-95
Cape Coral, Florida
2004 Dmax (gone)
2005 Dmax (gone)
2010 Dmax (gone)
MiamiMax is offline
post #4 of 14 (permalink) Old 08-07-2019, 01:14 PM
Are they all visible from crawling under/around the truck?
bam5128 is offline
post #5 of 14 (permalink) Old 08-07-2019, 01:25 PM
DaJokr's Avatar
Might require being a monkey, but should be able to if you pull wheel liners
Beastly Build
LBZ Drag Racing
2006 GMC LBZ 4x4 CC/SB
1/4 Mile [email protected]
1.793 60'
DIED 09/19/17 11:02AM
REVIVED 12/21/17 3:57PM
DaJokr is offline
post #6 of 14 (permalink) Old 08-07-2019, 01:30 PM
MiamiMax's Avatar
Most of the time you wont be able to, cause the engine forces the mount shut, but if you can have someone step on the brake while the truck in gear and try to rev a little at a time you should be able to see the engine lifting and probably hear the sound it makes.
Ssgt. USMC 85-95
Cape Coral, Florida
2004 Dmax (gone)
2005 Dmax (gone)
2010 Dmax (gone)
MiamiMax is offline
post #7 of 14 (permalink) Old 08-07-2019, 02:43 PM
Just tried it on my way home from work to see if I could duplicate the noise with the brakes on. Nothing but a little spin on the tires
bam5128 is offline
post #8 of 14 (permalink) Old 08-08-2019, 08:01 AM
Sorry for kind of hijacking your post Blumaruder...
I have also noticed that on occasion I will hear the same noise when coming to a stop leading me to believe it may be suspension related (ball joints? Control arms?)
Also, 2006 ECSB 4X4 133k miles. Drivetrain and suspension is stock.
bam5128 is offline
post #9 of 14 (permalink) Old 08-08-2019, 08:08 AM
MiamiMax's Avatar
If coming from the front end, jack the front of your truck and with the wheels off the ground move your wheels on a 12/6 motion and then from 3/9 motion, if anything is loose or worn out you should be able to tell.
Ssgt. USMC 85-95
Cape Coral, Florida
2004 Dmax (gone)
2005 Dmax (gone)
2010 Dmax (gone)
MiamiMax is offline
post #10 of 14 (permalink) Old 08-12-2019, 10:46 AM
Had a buddy with me this weekend who got out and stood next to the truck to listen. He said he feels like it's coming from around the middle of the truck. The noise also seems to be getting worse/more common. I was getting it when I had it in drive and would go back and forth with hitting the brakes and letting off without hitting the throttle.
bam5128 is offline
