06 LBZ Coolant Leak? - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By HWI
post #1 of 6 (permalink) Old 09-04-2019, 01:09 PM Thread Starter
OK Im baffled...
06 LBZ, Stock,185K miles. Got a low coolant notice on the dash, level was just below the seam on overflow tank. Let it cool for 2 - 3 hours, topped off to fill line. Drove it about 100 miles next day, no problems. Checked when I got home, coolant level was 1/2 above seam on tank. Checked it next morning, level was same, opened top of tank an a small bit of pressure bled off and level went to where I had filled it to. Drove to work the next morning then home again (about a 15 mile round trip), when I checked it again the level was at the seam. This morning I checked it, level was back to where I had filled it, when I got to work it was down to 1/2 over the seam. Drove it about 4 miles then checked, level was back up to where I had filled it.
Truck has not overheated (200 max), coolant level never below middle of over flow tank, upper radiator hose not hard when running at temp, no coolant in oil I can see, no smell.
Im baffled, any ideas?
Capt. Crunch is offline
post #2 of 6 (permalink) Old 01-12-2020, 04:40 PM
Solo Ascent's Avatar
Did you ever get this resolved?
2004 LLY Duramax.
Silverado Crew Cab LT
Solo Ascent is offline
post #3 of 6 (permalink) Old 02-04-2020, 05:40 PM
rock4xfab's Avatar
My guess is water pump. I’ve been chasing this for awhile and finally saw a leak and it’s from the weep hole, hard to find with no huge puddles in the driveway coolants in the truck and Friday is the day. Just ticked because I just put idlers, belt tensioner, belt on last January. I should have bit the bullet then
File Type: jpg D562B520-97AC-4F11-98DA-0EDBDE7B2300_1580863173707.jpg (25.4 KB, 40 views)
2006 SIERRA CC SB 2500HD 6.6 LBZ 179,000 and ticking
3" MBRP Down Pipe
4" Diamond Cat Back
5" SS tip
Edge CTS2
Intake resonator Plug
EFI LIVE DSP5 by ATP via BBP
AIRDOG2
Interior lighting to BLUE LED conversion
285/75/16
Leveling keys POWERSTOP Brakes.
rock4xfab is online now
post #4 of 6 (permalink) Old 02-06-2020, 07:25 AM
HWI
HWI's Avatar
I had coolant loss that took me a bit to figure out, no puddles or drips, turned out to be the EGR cooler cracked internally. Luckily my EGR fell off, so I haven't had to worry about that since.
DMAXfirefighter likes this.
06 LBZ CCSB
With some stuff.
HWI is offline
post #5 of 6 (permalink) Old 02-23-2020, 03:02 PM
I had a leak similar to yours, i could not figure it out for the longest time. Turned out my leak was from the heater hose connection off the firewall, it was leaking while it was running just a few drips at a time. Its about a $6 part and a good 15 minutes to change, havent had any issues again so far.
DaStud10 is offline
post #6 of 6 (permalink) Old Today, 11:04 AM
Just saw a video on a leak I hadn't seen before. Folks were towing with their LBZ and the hose burst that goes to the turbo. He had something like 250k on the odometer. Just food for thought.
"The Double D": 2007 Chevy 2500HD Classic LT2
6.6L LBZ, CC, LB, 2WD
Factory 16" Rims/Tires, Camper Mirrors (leveled),
Fingered and Blocked
PCV reroute
Factory Exhaust Brake mod
Curtis Cienfuegos is online now
« LBZ Prices | - »
