Egr delete questions - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 03-31-2019, 02:25 PM Thread Starter
Hi guys I just joined the forum I'm sure this has been asked but I just got an 07 lbz 210k miles bone stock from an older guy took good care of it it's my first diesel I'm not looking for max power out of a 200k mile duramax but I do tow a little and I'm looking to delete it and do efi live with the edge monitor I planned on just buying parts every check and putting it all together in a month or so but first things are lift pump and exhaust this week I go back on hitch in a week so they'll probably sit at home till I'm back. I've been looking into egr deletes I know not to just to just do blocker plate or anything like that I've looked into y bridge and all that but my question is can I just buy a y bridge kit that has the y bridge and cold side piping and an up pipe or are there other parts a delete kit for it comes with? I felt like the best way to do it right the first time would be the y bridge to avoid boost leak and the up pipe to not have blocker plates but if I buy both of those am I going to be missing any parts for that delete? I know I cant install until tuning but I'm making sure I wont be missing parts when I order this
Thanks guys
Brad07lbz is offline
post #2 of 4 (permalink) Old 04-03-2019, 08:06 AM
generally yes if you get a kit from a reputable company then it will, for the most part, include the parts needed. if you don't have a lb7 uppipe or welded one already then some kits have an option to add one for an additional price. but they generally include the y-bridge itself and the charge pipe to delete the egr and cooler system.
2010 GMC Sierra 2500 CCSB Black, 5"'straight piped, EFI
RobsRedRacer is offline
post #3 of 4 (permalink) Old 04-03-2019, 11:46 AM Thread Starter
Ok that's what I was wondering if those 3 pieces were all I needed I only saw the werhli kit giving me the option but wasn't trying to break the bank in deleting it. Thanks!
post #4 of 4 (permalink) Old 04-03-2019, 05:55 PM
HWI
HWI's Avatar
If you are trying to do it on the cheap then don't replace the charge pipe or y-bridge. Delete the egr cooler and egr valve, cap the holes on the stock charge pipe, replace the passenger up pipe with an LB7 piece and get the coolant hose extension.
06 LBZ CCSB
MBRP 3" down pipe/4" straight pipe, PPE Xcelerator, FASS 150, Beans sump, deleted, pump rub fix
Zone 6" lift, Kryptonite tie rods
HWI is offline
Similar Threads
EGR Blocker vs EGR Disable vs EGR Delete bryan_duramax 06-07 LBZ & LLY Duramax Powertrain 29 06-26-2015 08:10 PM
Egr blocker plates vs egr delete vs egr delete w/ up pipe LML'12 11-16 LML Performance Parts Discussion 22 05-21-2014 11:07 AM
After tons of searching- still confused on EGR delete or no EGR delete IllDuramax General Discussion 1 02-01-2013 04:37 PM
egr blocker vs. egr delete brabg 07.5-10 LMM Performance Parts Discussion 0 05-28-2012 10:54 AM
EGR Block or EGR Delete??? Cdn_Blair 04.5-05 LLY Duramax Powertrain 16 08-16-2011 10:12 AM
