Electrical Problems- B/U & signals - Page 3 - Chevy and GMC Duramax Diesel Forum
 10Likes
post #21 of 40 (permalink) Old 07-01-2019, 06:15 PM
J83
J83's Avatar
Originally Posted by KdNicoll View Post
What button do you gotta push to get these lights working. Never seen mine on. (Marked in red).
Sent from my Pixel XL using Tapatalk
you will see those in the reflection of a glass window or door if you pull into a parking space in drive, they turn off in park though. They are only on in the day time when the truck is in gear. there basically just marker lights so that your truck has some lights on even in the day time.
KdNicoll likes this.
TCM & ECM Tuning by MotorOps
Y Bridge delete with SS up and down pipes
4" MBRP downpipe back exhaust with muffler
J83 is online now
post #22 of 40 (permalink) Old 07-01-2019, 06:53 PM Thread Starter
KdNicoll's Avatar
Thanks. And those bulbs on both truck are blown. Good to know.
2003 GMC K2500 HD CC LB 4x4 LB7 EFI Live DSP5 New Bosch injectors 6" Fabtech Lift 4" straight exhaust,Cognito Traction bars Rare Parts Idler and Pitman arms 35x12.50 Toyo M/T's Airbags hooked up to 150psi onboard air comp K&N air intake FASS 150 lift pump MAG-HYTEC Trannypan &Diff cover Rancho 9000 shocks 10% Tint Cognito upper A arms Kryptonite Dmax store XD Lower Aarms Deathgrip tierods
2006 Chevy Silverado 2500HD CCLB EFI Live DSP5 4x4 6" Fabtech lift, Wehrli Trac bars S&B cold air intake scoop/box FASS 150 2015+ mirrors Firestone Airbags Kryptonite Deathgrip tierods and tons more
2015 Arctic Fox 29L
KdNicoll is offline
post #23 of 40 (permalink) Old 07-01-2019, 07:03 PM
LHN...We ARE the Joneses
If you decide to try an LED in the DRL position, make sure they're good for 20v or they'll be toast in a short time too.
Hook'em_Horns! is online now
post #24 of 40 (permalink) Old 07-01-2019, 08:28 PM Thread Starter
KdNicoll's Avatar
I was wondering why they were the only incandescent lights left in the truck. Happens to be the lights you see burnt out in every old chev. Thanks for the info. I was thinking those dual filament DRL's might be a part of my problem... causing the fast flash. I guess I'm still not sure where I'm getting the fast flash from...
2015 Arctic Fox 29L
KdNicoll is offline
post #25 of 40 (permalink) Old 07-01-2019, 11:26 PM Thread Starter
KdNicoll's Avatar
So I'm also curious why I've gotten 5 codes in the last week concurrent with the lights issue. I haven't got 5 codes in the last year I've owned her.
P0650
P0646
P0381
P2563
P1631
This is a bunch of bullshit I think. Bogus?
2015 Arctic Fox 29L
KdNicoll is offline
post #26 of 40 (permalink) Old 07-01-2019, 11:39 PM Thread Starter
KdNicoll's Avatar
So you don't have to look them up. Ideas??
2015 Arctic Fox 29L
KdNicoll is offline
post #27 of 40 (permalink) Old 07-02-2019, 09:23 AM
J83
J83's Avatar
also, test them before you put the lights back together because those you can install backwards and they will not light up. Ask me how i know.
J83 is online now
post #28 of 40 (permalink) Old 07-02-2019, 12:24 PM Thread Starter
KdNicoll's Avatar
Why are the DRL's dual filament bulbs?
2015 Arctic Fox 29L
KdNicoll is offline
post #29 of 40 (permalink) Old 07-02-2019, 12:36 PM
J83
J83's Avatar
maybe they run them in parallel for higher output? not sure, theres only 2 wires to that plug if memory serves so the bulb only serves one function.
J83 is online now
post #30 of 40 (permalink) Old 07-02-2019, 02:31 PM Thread Starter
KdNicoll's Avatar
Any idea as to why the barrage of codes?
2015 Arctic Fox 29L
KdNicoll is offline
