CAT and DPF UnDelete - Page 2 - Chevy and GMC Duramax Diesel Forum
 2Likes
post #11 of 18 (permalink) Old 11-21-2019, 08:30 PM Thread Starter
I did consider registering there, but I guess Missouri requires the emissions system to be checked when transferring an out of state vehicle in, so I figure I'm screwed either way.
I wonder if the truck would run okay, without throwing a check engine light, if I just installed the CAT and DPF and ran to emissions really fast, then remove it until I move and have to go through the Missouri inspection. Emissions is only 5 minutes from my house.
Any thoughts?
jokes54321 is offline
post #12 of 18 (permalink) Old 11-21-2019, 08:36 PM
D_R_C's Avatar
Cat won’t cause a problem, in fact you wouldn’t notice any power, egt, boost differences with or without the cat.
What you will notice is the exhaust isn’t as stinky, that’s the emissions part with no sensors.
As far as the DPF being put back on and still tuned
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #13 of 18 (permalink) Old 11-21-2019, 08:45 PM Thread Starter
Thanks for the quick reply. I suppose it's only a few hours work. If it's not raining in the morning I'll throw the parts on and make the trip to emissions and let everyone know.
Denny
post #14 of 18 (permalink) Old 11-21-2019, 11:20 PM
D_R_C's Avatar
Hopefully you have a scanner to clear codes if needed, it wonít pass if you have any trouble codes.
What part of Phx are you located ?
Dan
D_R_C is offline
post #15 of 18 (permalink) Old 11-22-2019, 07:03 AM
Take advantage of the yearly rebates offered and stick with the 1300, instead of the more costly brands.
Or whenever walmart clearances any of their oils
I hope it doesnt go bad. I'll have that fourth bottle for at least 5 years. Eh, same price as bar oil so i guess ive got a plan b
07 Bowtie LMM CCSB Z: Nice truck, mad wife, empty wallet.
With all this "gun control" talk I haven't heard one politician say how they plan to take guns from criminals, just law abiding citizens.
knotReally is offline
post #16 of 18 (permalink) Old 11-22-2019, 02:35 PM Thread Starter
I'm in Mesa, AZ.
The results are in and the truck passed emissions, .07 opacity. The loss of performance sure was noticeable and it didn't throw any check engine lights, so I guess I'm good until I move.
Thank you everyone,
Denny
post #17 of 18 (permalink) Old 11-22-2019, 03:11 PM
Any thoughts?
Missouri only requires a safety inspection if you are outside the greater STL area. You can Google what counties around the STL area require emissions. The safety check will look to see if the EGR and cat are in place. The inspections makes no mention of the DPF. FYI, Dean
Dean E is offline
post #18 of 18 (permalink) Old 11-23-2019, 05:07 PM
D_R_C's Avatar
I'm in Mesa, AZ.
Thank you everyone,
Denny
Good to hear you gotsíer passed.
Just keep the parts incase you ever need to put it back to stock for emissions law changes or selling it.
Curious did you connect all sensors on the DPF and leave your delete tune in ?
Dan
D_R_C is offline
