Duramax LMM Knocking: Injector or Cracked Flex-plate? Pt.1 Diagnosis - Chevy and GMC Duramax Diesel Forum
View Poll Results: What is the problem Knock?
Flex-plate cracked or bolts loose 1 33.33%
Injector Knock 1 33.33%
CP3 Pump issue or sensor 0 0%
Engine bottom end 2 66.67%
Something else 0 0%
No clue and good luck! 0 0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
 1Likes
post #1 of 12 (permalink) Old 12-09-2019, 09:05 PM Thread Starter
Hello DuramaxForum community. This is my first post, and for good reason.. I've been on this forum as a spectator looking for information to help diagnose my Duramax knock. After much research and visiting shops, I have made my own conclusion and will be dropping the Allison Transmission tomorrow. Please check out my Diagnosis video linked next.
See VIDEO: https://www.patreon.com/posts/duramax-lmm-or-1-32224165 /
Injector Knock or Cracked Flex-Plate diagnosis w/ 2009 Chevrolet Duramax LMM Dually. Give a guess in the comments section and stay tuned for Pt.2 where we drop the Allison Transmission to inspect and install new parts.
Removing the Allison transmission in a Duramax is a lot of work, so I better install some performance parts while i'm at it for preventative maintenance and improved driveability.
This episode we inspect the new Torque Converter and Flex-plate I ordered from #suncoastdiesel out of Florida to my location in Kelowna BC Canada. Featuring the GM-107X-3D billet triple-disc low stall 1800 RPM tight stator designed for towing applications., To be paired with the Suncoast Performance Diesel LBZ/LMM billet counter-balanced flex-plate. #injectorknock #crackedflexplate #duramaxknock
With changing to a 1800 RPM Low Stall performance stator from the OEM's 2200 RPM stator I hope to see a fuel mileage improvement.
File Type: jpg Schuberth racer Marcel Irnie AMA Pro SBK Road Atlanta.jpg (76.8 KB, 50 views)
File Type: jpg Irnieracing Hard Braking cropped 1080p.jpg (55.8 KB, 51 views)
irnieracing is offline
post #2 of 12 (permalink) Old 12-29-2019, 08:20 PM Thread Starter
Duramax LMM Knocking Pt.2: Allison Transmission Removal Ep.1
post #3 of 12 (permalink) Old 12-29-2019, 08:22 PM Thread Starter
Duramax LMM Knocking Pt.3: Allison Transmission Removal Ep.2
post #4 of 12 (permalink) Old 12-29-2019, 09:35 PM
Earnhardtfan's Avatar
Sounds like injectors knock to me or even worse, rod knock!!!! Good luck with the fix.
irnieracing likes this.
Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4.
EFI Live by Idaho Rob, 536K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Odyssey Extreme Batteries, Westin steps, Bilstein Shocks, Road Master Active Suspension, M/A Pump Rub Kit, PPE Trans Cooler, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100 w/ CAT 751, LLY FF Housing w/ Racor, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires.
ADRENALINE TRUCK PERFORMANCE
Lincoln Diesel Specialties
Merchant Automotive
Earnhardtfan is offline
post #5 of 12 (permalink) Old 12-29-2019, 10:43 PM Thread Starter
Duramax LMM Knocking Pt.4: Suncoast Diesel 1800-Low-Stall Converter & Billet Flex-plate Installation
post #6 of 12 (permalink) Old 01-04-2020, 06:56 PM
So, $4,000 in parts and labor and is it still knocking? Not saying the Suncoast converter is a waste of money, but this seems like just a ploy for youtube views and patreon $$$$.
Who diagnosed the "cracked" flex plate?
Have the injectors even been checked?
You can turn them off one at a time with a scan tool to see which one could potentially be knocking.
Just my $0.02 (USD).
Merchant Automotive
post #7 of 12 (permalink) Old 01-11-2020, 06:08 PM
Watched part 5 or 6 and saw cylinder #5 (passenger side, 3 back) had a balance rate of 16! That's a bad stick and that would cause the knock. If you don't replace it you can melt a piston.....
Merchant Automotive
post #8 of 12 (permalink) Old 01-12-2020, 11:47 AM Thread Starter
ahh you missed the whole story of that segment (Disabling each injector at a time with the Tech2) which puts all the other injectors balance rates into a haze.
To clarify my words, it showed balance rate of 16 when another injector was disabled.
Thanks for checking my series.. I gotta release the next episode.. Thx for the reminder.
post #9 of 12 (permalink) Old 01-12-2020, 11:52 AM Thread Starter
Duramax LMM Knocking Pt.5: Allison Installation & AMSOIL Fuel-Efficient ATF
post #10 of 12 (permalink) Old 01-12-2020, 12:33 PM Thread Starter
Duramax LMM Knocking Pt.6: Unplugging Injectors & AMSOIL Diesel Injector Clean
