Batteries good, will baaarely crank. Starter/Solonoid/GlowPlug Relay??? - Chevy and GMC Duramax Diesel Forum
 7Likes
post #1 of 14 (permalink) Old 01-07-2020, 01:50 PM Thread Starter
So may truck is having a helluva time starting at any temp below 40. The starter will crank for maybe a second before I no longer have juice, then I have to throw a trickle charger on it. I'm in the southeast, so had no real reason to fish out the block heater plug until the last few weeks. If the block heater is plugged up for a few hours prior, it'll start, but only if I haven't attempted to start it already. Otherwise it's block heater + trickle charger, a bit absurd for a single night at 40 degrees. It past winters, it's started without assistance down in the mid teens.
No codes, and I can see the voltage initially drop for a couple seconds for the glow plugs, then return to roughly 12-14. No other electrical issues.
Any ideas? Or more accurately, what should I be checking to narrow it down?
Kanalos is offline
post #2 of 14 (permalink) Old 01-07-2020, 02:07 PM
jdwarren's Avatar
You're measuring the battery open circuit voltage, not the voltage under load (which is what determines if a battery is good or not). Have the batteries load tested and report back; I suspect one (or both) are bad. If either is bad, replace both batteries.
AlisoBob, chevor and justapilgrim like this.
2017 Silverado 3500 LTZ (Summit White) | CC SB SRW | Z71 | Duramax L5P | Undercover Ultra Flex bed cover | Draw-Tite front receiver | AIMS 3kw inverter-charger | Titan Travel Trekker 50-gallon auxiliary fuel tank
jdwarren is offline
post #3 of 14 (permalink) Old 01-07-2020, 02:30 PM Thread Starter
I'm about to pick it up from the shop after work, but I got the impression the guys pulled the batteries to test them. I'll get clarification. Thanks.
(I'm not leaving it with them to further trouble shoot because I have to travel for work in the morning and need my truck full of shit)
Kanalos is offline
post #4 of 14 (permalink) Old 01-07-2020, 02:56 PM
Former GM Tech and parts
DMAXfirefighter's Avatar
Sounds to me like the batteries have voltage but no amps. Load testing is the only way to test that and see if they drop when a load is applied. We run into that a lot in the ag and turf world
John Deere Service Manager
DMAXfirefighter is offline
post #5 of 14 (permalink) Old 01-07-2020, 03:21 PM
jdwarren's Avatar
If "the guys" are not professional mechanics, make sure they're very clear about what they mean by "testing the batteries". Even a brand new battery may well drop to about 7V when under a starting load, so if they're telling you that they're at 12V or 12.5V or whatever that should indicate that they did not do an actual load test.
If the truck runs fine once started and exhibits no charging system issues, I'd be willing to bet that you've got at least one bad battery. I'd throw out the possibility of bad connections between the batteries and starter but the fact that it seems to behave differently after the first attempt makes me think it's just plain old bad batteries. Can't hurt to check and clean/tighten the connections (12V and ground) anyway, though.
jdwarren is offline
post #6 of 14 (permalink) Old 01-07-2020, 08:21 PM
GoBlowSnow's Avatar
if your batteries are over 3 years old, I'd automatically replace them anyway. That's about the life of them on modern vehicles (2001 and newer) Make sure you do a charge on the new ones before you install as well, you want them to be full fresh.
2008 Silverado 2500 Crew Cab Z71
GoBlowSnow is offline
post #7 of 14 (permalink) Old 01-07-2020, 08:23 PM
GoBlowSnow's Avatar
Also- I'd throw the block heater/coolant heater/whatever the heck it is- on for about 2 hours prior to you starting it in the morning when it gets below 40. it really does help the truck start faster and the warmer the oil/block is when you do your first start up, the easier the oil will circulate and reduce damage/wear. It works!! Also be sure to run a full synthetic oil and premium oil filter. it WORKS. It Makes a difference!
post #8 of 14 (permalink) Old 01-07-2020, 09:00 PM
chevor's Avatar
Make sure they disconnect the cables so not reading both batteries under load test.
407driver and jdwarren like this.
2010 Gmc 2500 Duramax 853,500 Odometer miles - sold Nov 2018
2013 LT CCSB SRW bought with 508,000 miles, now over 674,000 miles
2013 CrewCab and chassis with 9' Hillsboro aluminum flatbed 84,000 miles. - Sold Sept 2019
chevor-2010-gmc-2500-maintenance-log
Favorite book : The Richest Man in Babylon
chevor is offline
post #9 of 14 (permalink) Old 01-09-2020, 06:04 PM
Solo Ascent's Avatar
Below 40! Holy crap! Turn the sun up 60 degrees and try again! That’s insane cold!
2004 LLY Duramax.
Silverado Crew Cab LT
Solo Ascent is online now
post #10 of 14 (permalink) Old 01-09-2020, 08:56 PM
RE: my IH2290
Would not start. Would not even make a "click" sound. Lights worked.
Both batteries checked out with Volt Meter.
Took them to my NAPA Dealer for load testing. One OK; One not OK; bought one new battery. Trickle charged them overnight.
Still same results. (Lights - Check.) (Start - Nothing.)
I had a similar problem with my CASE 580N. On that machine I left the new starter switch in but, bypassed it with a pushbutton in the starter circuit. (the fuel solenoid open/close operates off the starter switch. Runs like a charm.
So, I plan to bypass the starter switch with a pushbutton on my 2290. In this case the fuel system is all manual. Hope that works.
What do you think? Thank you in advance.
Duramaxx05 is offline
