2008 LMM transmission solenoid and 4x4 issues - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 01-08-2020, 12:29 PM Thread Starter
I currently have codes:
P0751 shift solenoid A performance or stuck off
P0756 shift solenoid B performance or stuck off
P0761 shift solenoid C performance or stuck off
P0894 transmission component slipping
Service 4 wheel drive also displayed on dash. Any ideas as to what this could be? Hoping it's not a failing transmission.
John LaClair is offline
post #2 of 9 (permalink) Old 01-08-2020, 01:29 PM
Do you have a wiring diagram? I wonder if those are wired from the same source and there is a problem in the wiring/fuse.
2006 Chevrolet Silverado 2500HD LT
chuckd83 is offline
post #3 of 9 (permalink) Old 01-08-2020, 02:21 PM Thread Starter
I don't have a wiring diagram, but after messing with the fuse block and moving around some relays, the run/crank relay wasn't making a connection so the truck won't even crank. Pulled out the fuse block and found a couple of broken wires, not to mention the fuse block is corroded internally and coming apart. Going to replace that and hope that it fixes my problems.
post #4 of 9 (permalink) Old 01-08-2020, 06:51 PM
Wiring diagrams can be obtained from GMUPFITTER.COM in the body builder section. Electrical is in it's own manual, by year/model.
Ron Nielson
Ron Nielson is online now
post #5 of 9 (permalink) Old 01-09-2020, 04:02 PM
The wiring diagram from the above link is here:
https://www.gmupfitter.com/files/med...hassisCabs.pdf
Fuse 22, TRANS IGN 1, 15A powers:
Transmission Control Module (TCM),
1-2 Shift Solenoid (1-2 SS) Valve,
2-3 Shift Solenoid (2-3 SS) Valve,
3-2 Shift Solenoid (3-2 SS) Valve (M30/M70),
Torque Converter Clutch (TCC) Solenoid Valve (M30/M70),
Torque Converter Clutch Pulse Width Modulation (TCC PWM) Solenoid Valve
chuckd83 is offline
post #6 of 9 (permalink) Old 01-09-2020, 04:08 PM
Sorry, that's gas.
Fuse 15, TRANS IGN 1 Fuse:
Front Axle Actuator (NQF/NQG)
chuckd83 is offline
post #7 of 9 (permalink) Old 01-18-2020, 10:59 PM
Is this only happening when cold?
Nicksquid is offline
post #8 of 9 (permalink) Old 01-20-2020, 04:30 AM Thread Starter
Definitely seems like it could be. The first time I wasn't paying attention to the temperature, but the last two times it has been below 20 degrees when it had these codes pop up. Let it warm up, clear the codes, and I don't have any more issues out of it until it gets cold again.
post #9 of 9 (permalink) Old 01-20-2020, 06:19 PM
aautio1004's Avatar
sorry to hope into your post here, but i’ve got the same issue on my truck, same codes minus the service 4 wheel drive message...but it’s definitely only when it’s cold out on mine. transmission won’t go into gear until i clear the codes out, and then it’s all good again until the next time it’s really cold out. then the process repeats itself.
just wondering, do you happen to have any sort of manual locker switch for your transmission at all? i’ve got one on mine and i’m just trying to eliminate that as the source of the problem.
07 LBZ Allison Auto 4x4 crew cab long box LT2 Edge Juice w/ Attitude SOLD
01 Ram 2500 Cummins QC SB 5 inch exhaust HX40 turbo Smarty/Edge Comp Hot stack SOLD
85 Chev 1500 dropped to the ground..6.2L til it blew...now runs with a 454
14 Chevy Cruze 2.0 diesel
08 CCSB LLM-trying to figure out what allís been done to it......
aautio1004 is offline
