Coolant leak on passenger side floor - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 01-16-2020, 09:44 AM Thread Starter
skierz's Avatar
2009 Chevy Express Cargo 6.6L Duramax van converted to camper. Had a slow coolant leak for quite some time now Had it up on a lift to fix something else and could see coolant on a downpipe and splashed around some other hard to reach areas. No coolant in oil. Saw on youtube someone traced a similatr issue to a adapter plate. I've tried K-seal a few times and it held for a few days but eventually leaked again. Any insights are welcome. thanks!
skierz is offline
post #2 of 4 (permalink) Old 01-16-2020, 11:40 AM
407driver's Avatar
Is your heater core located on the right side anywhere near the location of the coolant on the floor?
Im not familiar with the vans but the two hoses on the pickups that connect to the heater core use a plastic quick disconnect that are very prone to leaking.
If this is the issue the fix would be to remove the quick disconnect and replace that entire hose all to the way to the other end with a new hose and worm gear clamps. You could use a coupling and worm gear clamps to add to the existing hoses but I always find it is best to replace those old hoses anyway while doing repairs of this type
407driver is online now
post #3 of 4 (permalink) Old 01-16-2020, 12:03 PM Thread Starter
skierz's Avatar
Thanks for the response. To be honest, I'm not much of a wrencher nor am I well versed in these engines. That said, I do believe the heater core is near the passenger side. From what you're describing, it sounds like it would be a pretty big job relative to removing a lot of things to access the area that needs fixing, would you agree?
skierz is offline
post #4 of 4 (permalink) Old 01-16-2020, 12:32 PM
407driver's Avatar
It does require removal of some of the dash to gain access.. When you put your finger on the wet spot does it feel slightly smooth/slippery, like a bit of oil and/or is it pink colored? Does it smell sweet? don't taste it to see, if it is coolant it is poisonous.
I tried to find a you tube video that would explain how to do it but there were no good ones. I did learn though that it would entail taking apart the dash and that your heater core sits directly above the front center of your passenger side foot area beneath the dash
