Need help electrical issue - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Ron Nielson
post #1 of 5 (permalink) Old 01-25-2020, 02:16 PM Thread Starter
I bought a 08 LMM sight unseen from the auction. Truck is super clean and has 107k miles. From what i can see it has a 5 inch exhaust and a 5 position tuner on it. When i arrived at the auction to get it I started it right up and a bunch of lights came on the dash. CEL, Brake, ABS, tire pressure. Then the transmission would work. It would be stuck in neutral. I shut the truck off and it would work for a minute again before going out again. The auction plugged into a generic scanner and said it showed a trans shift solenoid, body control module, and wheel speed sensor. I think its an electrical problem and not a transmission. Please help!!!
Diesel Donkey is offline
post #2 of 5 (permalink) Old 01-25-2020, 02:55 PM
Well, I think we know why it went to auction. Sounds like you have multiple issues. Get a good scanner and start chasing one code at a time. Might start with getting it flashed back to stock. Sounds like whoever's been tinkering with it made a mess.
Nitro Junkie is online now
post #3 of 5 (permalink) Old 01-25-2020, 04:14 PM
If you're going to make this truck run, you'll need some tools, namely a subscription to ALLDATADIY.COM that tells you about your truck, DTC codes, wiring, etc. Then you'll need a code reader that will read all the computers in your truck and erase the codes also. I currenrtly use Bluedriver which costs $100 and will even work with my Mercedes, but there are lots of capable readers on the market, from $20 to whatever you want to spend. Make sure your batteries are fully charged before working on it and remember that every electrical device, motor, sensor, etc also has to have a properly working circuit to support that device. When you read for DTC's I'd likely go after any U% codes, get everything communicating first, then pick another code and see if you can fix that one. It often happens that fixing one thing also fixes another 2 or 3 things.
Best of luck to you
407driver likes this.
Ron Nielson
Ron Nielson is offline
post #4 of 5 (permalink) Old 01-25-2020, 08:58 PM
407driver's Avatar
These trucks DO NOT play well with low voltage. Before I did anything else Id check the date on the batteries, check the voltage and have them load tested.
If Either battery fails replace them BOTH. Id do this first before anything else.
If that does not solve the issues, follow Ron's advice. No need for me to restate what he said so well.
When you get er running, this thread will help you maintain it. Here is the link:
https://www.duramaxforum.com/forum/m...ew-owners.html
I am hoping that you will get off cheap. I do hope Im wrong but that DSP5 switch usually means 5 tunes and some are too hot for a stock trans. A trans rebuild from a good sop will set you back 4-5000 so I hope you did not pay too much for it at the auction.
407driver is online now
post #5 of 5 (permalink) Old 01-25-2020, 10:07 PM
jdwarren's Avatar
If it starts and runs and has a functioning alternator I don't see how bad batteries could cause these problems. Personally I would hold off on replacing anything on this truck until a full accounting can be made of its issues.
To the OP, I'd get a copy of the factory service manual and a scanner, as was already suggested. I second the Bluedriver recommendation because when it detects a code you can use the app to "share" the code via an emailed PDF. Very useful for communicating with dealerships and tracking your work.
2017 Silverado 3500 LTZ (Summit White) | CC SB SRW | Z71 | Duramax L5P | Undercover Ultra Flex bed cover | Draw-Tite front receiver | AIMS 3kw inverter-charger | Titan Travel Trekker 50-gallon auxiliary fuel tank
jdwarren is offline
