Axle Tube Gasket??? - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 04-01-2019, 07:20 PM Thread Starter
Axle Tube Gasket???
So i dropped the axle tube housing coming off of the passenger side of front differential to change the leaking axle seal at the end of the tube put it all back together and now i have a leak where the axle tube housing bolts to the differential. There was not a gasket or rtv on it when i removed it. Is there a gasket for it or can i use rtv or should it take anything at all? Its leaking so i will have to put something anyhow. Thoughts?
Derrick, Moreauville, Louisiana
2007.5 Silverado 2500HD LMM
EFI live, straight pipe, S&B, sinister EGR delete.
Dmax1309 is offline
post #2 of 3 (permalink) Old 04-02-2019, 03:17 AM
830king's Avatar
It's been awhile but I think I remember using rvt on mine.
Sent from my SM-G930V using Tapatalk
My name is Dan, I drive a 2005 2500hd ccsb lly 4x4, victory red, Efi live Robs trans safe tunes, Edge cts w/pyro, Silverline 5" exhaust, Magnaflow downpipe, LML ds manifold, Arp head studs, S&b turbo inlet, S&b cai dry filter, Ppe shim kit, drilled fuel rails, B&w turnover gooseneck, Ma welded waterpump, Profab egr delete, Fass titanium 150, Beans fuel sump, Ma pump rub plate, 285/75-16 duratrac on stock rims, Kryptonite tie rod & centerlink, Kryptonite sway bar end links, kryptonite lower ball joints Rare parts extreme duty pitman and idler arms, Dhd steering brace, Alligator 5/8" trans lines.
830king is online now
post #3 of 3 (permalink) Old 04-02-2019, 04:13 AM Thread Starter
10-4 thanks
Dmax1309 is offline
Similar Threads
RDS tank install Q..inner vent tube/fill tube..? IndyMatt Towing & Hauling 0 04-12-2013 04:39 AM
Axle Tube???? crazycrew Drivetrain 2 10-12-2010 09:54 PM
AFE intercooler tube (oil in tube) jer27 Performance Upgrades 3 02-10-2010 03:41 PM
Price for Afe Intercooler Tube or Banks Intercooler Tube? Lucas Ryan Vendor Price Request ( Site Vendors Only Respond) 3 02-03-2010 02:52 PM
axle tube bracket? mikes454 Drivetrain 2 04-14-2009 10:10 PM
