08 LMM change fuel filter warning - Page 2 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #11 of 17 (permalink) Old 04-09-2019, 08:51 PM Thread Starter
BrandonB's Avatar
Originally Posted by Ron Nielson View Post
Originally Posted by BrandonB View Post
Just when I need more fuel it says change fuel filter?
Do you mean that after your fill up, or add fuel, then the problem occurs? Please explain.
I mean I don't notice a difference either way. It's just when I step on it going uphill. I found a kinked line today behind my turbo intake hose. Going to assume that's part of the problem and replace them. I put a hose clamp on and went uphill and no change fuel filter. Yet.....
Thank you
BrandonB is offline
post #12 of 17 (permalink) Old 04-13-2019, 05:16 PM Thread Starter
BrandonB's Avatar
Replaced the fuel lines that were collapsed and still got the change fuel filter. Drive it with computer hooked up. Injectors 3-4 we're a little high but not out of range. Any ideas? Mobile mechanic is going to replace fuel pressure relief valve.
Thank you
BrandonB is offline
post #13 of 17 (permalink) Old 04-21-2019, 08:21 PM
DuraDust's Avatar
Send a message via AIM to DuraDust Send a message via MSN to DuraDust Send a message via Yahoo to DuraDust
I had the exact same problem last year. Rebuilt fuel filter head & replaced head lines. No change. Put a FASS flow enhancer on it and it hasnít done it since.
2007.5 CCSB RAWLINGS EDITION
6" TUFF COUNTRY, FABTECH T/R,
MOOG PITMAN / IDLER / UCA's
18X9 FUEL Maverick's stompin on LT 295/70 18 NITTO Trail Grappler MT's
NESA B/U camera / H/L all on / MBRP DPF back exhaust / CURT XD hitch / RIDE-RITE airbags / F/M antenna hidden
FASS flow enhancer / 15' GM Nerf Bars / Pioneer MVH-1400NEX / Infinity REF-6522ix / Debadged / Cquartz ceramic wheels & H/L
DuraDust is offline
post #14 of 17 (permalink) Old 05-07-2019, 08:31 PM
dl0310's Avatar
I had the same issue only when I was towing, the supply hose on top of the tank was collapsing and i changed 4 filters on a trip before I started chasing fuel hoses.
I installed an AirDog...be warned your stock primer seals will leak after the lift pump is installed recommend replacing the seals while the truck is down for the lift pump.
Good luck.
2008 2500HD 4x4 CrewCab All stock (for now), Airdog Lift Pump
dl0310 is offline
post #15 of 17 (permalink) Old 05-07-2019, 09:15 PM Thread Starter
BrandonB's Avatar
[QUOTE=dl0310;12156141]I had the same issue only when I was towing, the supply hose on top of the tank was collapsing and i changed 4 filters on a trip before I started chasing fuel hoses.
I installed an AirDog...be warned your stock primer seals will leak after the lift pump is installed recommend replacing the seals while the truck is down for the lift pump.{/QUOTE]
I replaced the pressure relief valve with a racing valve and haven't had the problem again. I did however get low oil pressure while stopping after pulling up hill for a while. That should be fun.
Thank you
BrandonB is offline
post #16 of 17 (permalink) Old 05-08-2019, 06:01 PM
dl0310's Avatar
LOL sounds like a typical GM...fix one problem to find another at least it is not a Ford, they just circle the problem with a blue oval. Good luck on figuring out your oil pressure problem.
dl0310 is offline
post #17 of 17 (permalink) Old 05-08-2019, 08:02 PM
Just found this. The hose is kinked and a little soft. Added a hose clamp to straighten it out. Could this be the issue?
That is likely your issue. Mine was pretty bad but I've yet to pull with mine (goose that is) which is why I think i've tip-toed around getting the p0087/fuel filter codes people mention on here.
Check out that link. I posted some decent info on hoses that might be of help.
07 Bowtie LMM CCSB Z: Nice truck, mad wife, empty wallet.
With all this "gun control" talk I haven't heard one politician say how they plan to take guns from criminals, just law abiding citizens.
knotReally is offline
Similar Threads
How to change fuel filter on a 2008 got the "Engine Power Reduced" change filter code CustomBagger General Discussion 17 01-06-2014 06:47 AM
08 lmm change fuel filter light? chadsdurty08 07.5-10 LMM Duramax Powertrain 14 08-31-2011 05:19 AM
ABS warning light and service brake warning light? rugby999 2001 - 2007 (GMT800) Non Powertrain 1 11-23-2010 09:29 AM
How to change an 08 LMM fuel filter?? jay6918 General Discussion 7 03-17-2010 08:22 PM
Brake Service - warning message, no warning lights lost_in_calgary 911 Problems Forum 2 01-23-2010 07:47 AM
