Fuel Injector Pump Catastrophe - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 05-31-2019, 10:51 AM Thread Starter
Has this been a common malfunction in LMM's. Recently, my 2008 with 45,000 miles would not start. Towed to the dealership for what I hoped was just air in the fuel line. Wrong. It appears the fuel filter housing/system wasn't getting fuel to the injector pump. Therefore, metal shavings from the pump was introduced to the entire fuel system. Needless to say, replacing and flushing the fuel system which includes fuel filter/housing, injector pump, injectors, fuel rail/lines and drain/flush the tank is $15K. Contacted GM to see whether they would bear some of the cost due to defects in materials. Unfortunately, the age of the truck nullified any support. Don't get me wrong, I've had a smile on my face since day 1 owning this tow vehicle but this surely puts a damper on it. For GM to put the burden of this cost on the consumer is absurd and not for the lack of maintenance.
switchin is offline
post #2 of 13 (permalink) Old 05-31-2019, 11:27 AM
cdub311's Avatar
Welcome to the forum, I would find another shop and/or get a second opinion. Find it hard to believe a CP3 would do the same damage as a CP4 in a LML. @ 45K miles, sounds like a wallet flush to me. pay and diagnostic charge and tow it elsewhere.
AlisoBob likes this.
2006 GMC LBZ CCLB PPE down pipe 5" after the cat. PPE airbox mod. ATP EFI Live DSP5. CTS 2. Air Dog 165-4G.
Leveled with Bilstien 5160 front 5100 rear. PYO wheels with 285/75/16 AT
cdub311 is offline
post #3 of 13 (permalink) Old 05-31-2019, 12:26 PM Thread Starter
Thanks for your input. Fortunately I was invited to come and look and talk with the mechanic. He showed me the shavings in multiple places. Fuel line ports top and bottom. He also pulled a sample from the fuel cell. It looked like he was panning for silver. Anyway, spoke with an independent repair and fuel system shop to see if I could save some cash, but no. They estimated 14-16K too. I'll just have to tell the wifey that the bathroom upgrade is on hold...
switchin is offline
post #4 of 13 (permalink) Old 05-31-2019, 01:25 PM
You need to find a new shop.... The amount they are charging you for labor is absurd.
$3k for parts....
https://www.ebay.com/itm/LMM-2007-20...cAAOSw2ChcNZOn
$13k in labor?
AlisoBob is offline
post #5 of 13 (permalink) Old 05-31-2019, 01:38 PM
Wow, a 2008 with only 45k on it. If your filter housing was pulling air and starving your CP3 it is hard to believe you have not seen any issues up to this point. Normally there should have been numerous issues where the pump has lost its prime and caused you to hit the primer bulb. Just one more reason to have a good lift pump on these Duramaxes. Just make sure if you get a lift pump it does not put out more than 10 psi of pressure to the CP3. Dean
Dean E is offline
post #6 of 13 (permalink) Old 05-31-2019, 01:44 PM Thread Starter
Dealer won't use refurbished parts. I had the Service Consultant confirm the price while I was there, $880 per/injector. I'm just not familiar where else to take it near San Jose. The other shop I tried had the same bottom line. OUCH!
switchin is offline
post #7 of 13 (permalink) Old 05-31-2019, 01:59 PM Thread Starter
Thanks Dean. Thinking back and 2 to 3 weeks prior, during a regen while idle at a stop, I heard a momentary chatter that didn't carry over continuously. Didn't put too much thought into it. I'm beginning to think that an o-ring was going bad at the filter housing causing air to be introduced to the pump and the end result is complete contamination. Towed my camper a week prior without incident and after the momentary chatter noise.
switchin is offline
post #8 of 13 (permalink) Old 05-31-2019, 02:49 PM
SilverGorillaLML's Avatar
Find a diesel performance shop that's local or close enough to tow. They should do it much cheaper. 800 an injector is ridiculously expensive. The fuel rails and lines could be cleaned and re used imo and the cp3 should be 7 to 800.
Nic
2011 GMC Sierra 2500 cc/sb LML Quicksilver
Has some stuff to make it go fast and blow up sooner.
2 Banks performance dpf's, 2.5 egr coolers, 3 Def tanks filled with meth, custom hot air intake, snail mod,
garden hose ran from fass, 16 John deere injectors, 22x16-378 forces, and like sooo many stickers brah
Wiles Diesel Performance
Woodstock, Va
post #9 of 13 (permalink) Old 05-31-2019, 05:01 PM
Seriously think about a lift pump. There are many options available. I went with a FASS 95 which will support up to 500HP but there are quite a few options available to you. Opinions on this will vary about as much as bringing up which oil everyone prefers. The biggest thing is to make sure you do not over pressurize the pump. Make sure what ever you go with will not put out more than 10 psi. All you really want is some slight head pressure to the CP3 to keep it happy. Dean
Dean E is offline
post #10 of 13 (permalink) Old 05-31-2019, 10:03 PM
What maintenance could one overlook in the fuel system that could cause $13k in repair at 45k miles? Seriously? I realize there are a lot of factors that play into this. given age and mileage, corrosion is the top one. But, corrosion can quickly be identified or eliminated by investigating other components.
Bro, best of luck.
07 Bowtie LMM CCSB Z: Nice truck, mad wife, empty wallet.
With all this "gun control" talk I haven't heard one politician say how they plan to take guns from criminals, just law abiding citizens.
knotReally is online now
