Coolant leak drivers side front of engine. - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 07-15-2019, 07:44 PM Thread Starter
I have a 2009 GMC 2500HD with the LMM engine. I recently developed a coolant leak on the right front of the drivers side. I added dye and it appears the leak is from above the oil cooler tube behind the water pump. Any ideas? It’s a drip-drip-drip leak, hits the skid plate and runs to back and drips to the ground.
Hangingnstl is offline
post #2 of 5 (permalink) Old 07-17-2019, 07:52 AM Thread Starter
Upon further review with a borescope the leak is running down behind the oil cooler tube and about 2 inches behind where the oil cooler tube connects to the water pump. Its right above where the most forward bolt in the block that holds the radiator shroud. I hate to think its a leaking head gasket, but I'm running out of ideas.
post #3 of 5 (permalink) Old 07-17-2019, 11:42 AM
There is a block coolant drain plug in that area you can check.
2018 L5P
2003 LB7
BIDSDiesel is offline
post #4 of 5 (permalink) Old 07-17-2019, 12:06 PM Thread Starter
I did see what I thought was a circular block stamp that had coolant dye in it. Does this drain plug have an allen wrench head? Ill try to get a picture tonight.
post #5 of 5 (permalink) Old 07-18-2019, 06:13 PM
No, if I remember right it should be a 18mm socket that fits it.
2018 L5P
2003 LB7
