Limp Mode Delete? - Chevy and GMC Duramax Diesel Forum
post #1 of 17 (permalink) Old 08-13-2019, 11:32 AM Thread Starter
Limp Mode Delete?
Is there any such thing available?
Over the course of owning my Duramax for the last 12 years, I have experienced far too many situations where the truck was set to limp mode and effectively stranded me for what turned out to be something simple. Something that before limp mode came along, would have been ignored or at the most thrown up a check engine light.
I paid good money for a DPF delete because it kept throwing me into limp.
I'd pay just as much to delete Limp Mode all together. Anybody got a source for that?
Spyder27 is offline
post #2 of 17 (permalink) Old 08-13-2019, 11:40 AM
J83
J83's Avatar
i dont think that you can do that, and im not sure doing it would be a good idea. If you are going into limp mode on a deleted truck, there is likely a problem that you should look into and not just delete the problem indicator away. Were you to delete this system you may be less aware of engine issues until it is WAY too late to do anything about them.
J83 is offline
post #3 of 17 (permalink) Old 08-13-2019, 01:21 PM Thread Starter
More than willing to take that chance at this point.
I work in an industrial environment and one thing I've learned about nuisance alarms is that if a non-critical alarm prevents an equipment operator from running, they will try to find a way to defeat it.
This is no different. If a truly critical parameter is not met it should probably displayed on the DIC all others should get no more than a check engine light. If critical enough maybe a "no start" condition. Chevy has decided to include a seemingly endless number of minor conditions to initiate limp mode. That is totally uncalled for.
I've driven most of my life without a baby sitter. Now a bad Oil level sensor can sideline my truck and always in 5:00 o'clock traffic. I learned how to check my oil with the dipstick a long time ago.
Yes, I would absolutely do it if available.
Spyder27 is offline
post #4 of 17 (permalink) Old 08-16-2019, 08:07 PM
Check out the section on ECM programming here:
http://www.kennedydiesel.com/docs/Du...ure%20code.pdf
shawn.o is offline
post #5 of 17 (permalink) Old 08-17-2019, 07:56 AM Thread Starter
Sorry shawn.o, didn't get your point.
Are you suggesting that if I buy an ECM programmer that I would somehow be able to delete Limp Mode?
Even if thats true, I'm not a programmer. I am just a guy who happens to own a Duramax and would like to keep it on the road more and off the side of the road less while I search for which non-GM product I will replace it with.
Spyder27 is offline
post #6 of 17 (permalink) Old 08-17-2019, 12:24 PM
D_R_C's Avatar
First you need a device to read the codes, the device will tell you what the code is and/or you can search the code number on the open internet, write the numbers down.
Then clear the code/codes which would also remove the limp mode.
Then repeat if the code comes back, but consider taking care of the reason the code popped up in the first place.
Thereís devices out there as cheap as $50 to $450 which is the Edge Insight.
You donít have to be a mechanic to do this, all you need to know is how to plug the device into the OBD2 port, pretty much the same as plugging a cord into your wall outlet.
Dan
EFILive TCM Duramax Tuner
D_R_C is online now
post #7 of 17 (permalink) Old 08-17-2019, 12:51 PM Thread Starter
Originally Posted by D_R_C View Post
First you need a device to read the codes,.
Thanks D_R_C, I have a scanner from PPEI.
Currently I have a code and that code will not reset (because the condition still exists). The problem is NOT that it has a code, the code it has puts me in limp mode and I don't consider any of the 5 sensors on that circuit to be life threatening like limp mode in freeway traffic is.
Yes I will replace the ECM when I can get the truck towed but then next time some little minor problem is detected it will limp again. I'm just tired of it. Emissions deletes are good. Limp mode delete would be beyond great.
Spyder27 is offline
post #8 of 17 (permalink) Old 08-17-2019, 02:02 PM
407driver's Avatar
You are correct that if it is a sensor it is a PITA!!
BUT, if the sensor is not faulty, an oil level sensor for example, ignoring it could be devastating for your engine.
IMHO even if possible, deleting entirely the limp system would be a VERY bad idea.
Bypassing the safety systems, effectively ignoring them, is an equally bad idea...........Ever hear of the Deep Water Horizon? How many times did people get away with that before that one time literally blew up in their face?
407driver is offline
post #9 of 17 (permalink) Old 08-17-2019, 02:21 PM
D_R_C's Avatar
So, whatís the code number your getting ?
This would help us possibly helping you.
Dan
D_R_C is online now
post #10 of 17 (permalink) Old 08-17-2019, 02:29 PM Thread Starter
Yes Sir Heard of It ...Live in Alabama.
Not a safety system, a Nanny system.
It's clear that some of you don't mind it. I just very badly want to take it off of MINE.
Spyder27 is offline
