Extremely hard radiator hose - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 15 (permalink) Old 08-13-2019, 05:35 PM Thread Starter
knightstilepro's Avatar
My radiator hose is rock hard after driving it. Coolant get up to around 210. Doesn’t overheat ever. I got a block tester today and the color didn’t change at all perfectly blue. Changed the thermostats this winter when it was -40. Seemed to work fine.
2008 Chevy 3500 6.6l lmm
Airdog 4g lift pump
Wcfab ybridge and egr delete.
Edge monitor with egr probe
PPE RACE FUEL VALVE
Efilive by Cory Willis and switch
Flatbed with Hydraulic hayspear
3 inch lift, lifts for less.
PVC re route
65mm upgraded turbo
51 gallon aux tank
knightstilepro is offline
post #2 of 15 (permalink) Old 08-13-2019, 05:42 PM
J83
J83's Avatar
The hose should be hard after driving it, the system is under 15 ish PSI of pressure while up to temp. That extra atmosphere or pressure raises the boiling point of the water in the system from 212 degrees to somewhere around 250 degrees. This is a good thing as it keeps the water from boiling inside the cooling system which would be undesirable (this is also why you get doused in boiling water when you take the radiator cap off a hot engine since the pressure drops allowing the water to spontaneously boil). So long as the hose is getting soft when the engine is cold, that is normal operation of the cooling system. If you think the system may be pressurizing more than the 2 ATM that its designed for they do make pressure testers for the cooling system that will tell you the internal pressure of the system.
TCM & ECM Tuning by MotorOps
Y Bridge delete with SS up and down pipes
4" MBRP downpipe back exhaust with muffler
J83 is online now
post #3 of 15 (permalink) Old 08-13-2019, 06:38 PM Thread Starter
Okay so what would cause there to be more psi then the 15psi if that is the case?
Airdog 4g lift pump
PPE RACE FUEL VALVE
PVC re route
65mm upgraded turbo
51 gallon aux tank
post #4 of 15 (permalink) Old 08-14-2019, 09:33 AM
J83
J83's Avatar
a blown head gasket is the most likely cause.
J83 is online now
post #5 of 15 (permalink) Old 08-14-2019, 10:31 AM
Or a faulty cap or whatever is in the system to prevent over pressure.
MIkey52 is offline
post #6 of 15 (permalink) Old 08-14-2019, 10:38 AM
J83
J83's Avatar
true, but the pressure would be coming from the water in the system based on the temperature of the water. so unless the head gaskets were leaking there would be a finite pressure you could reach at any given temperature. Given the OP is making it sound like the hose is rock hard with standard temperatures, that to me would indicate its more than just slightly over pressure, and the only way i see that happening is if there was a source of pressure in the system besides the water which leads me to headgaskets.
J83 is online now
post #7 of 15 (permalink) Old 08-14-2019, 11:11 AM
"THEEPASUCKS"
WOLFN8TR's Avatar
Disregard....
knightstilepro likes this.
2008 2500HD LTZ
EFI LIVE DSP5 - Edge CTS2 Insight - Transgo Jr.
6" Superlift - 35" Trail Grapp's - 18"Mazzi Hulks
Amp Research Steps - Billet Grille - PCV Reroute - DE Down Pipe - MBRP SS Exhaust
Cognito Braces - Fabtech HD Tierods - PPE Deep Pan - LML Manifold
WOLFN8TR is offline
post #8 of 15 (permalink) Old 08-14-2019, 05:24 PM Thread Starter
so why wouldn't the color change on the block tester if head gasket was bad?
Airdog 4g lift pump
PPE RACE FUEL VALVE
PVC re route
65mm upgraded turbo
51 gallon aux tank
post #9 of 15 (permalink) Old 08-14-2019, 05:27 PM Thread Starter
Originally Posted by WOLFN8TR View Post
Or in my case the oring on the hard pipe going into the water pump which was allowing the system to suck air. You can read all the details and the fix by clicking the link in my SIG “Hi-Temp Oring Kits”.
im not sure where to find SIG I don't know my way around this site yet. if its your signature I don't see what you're talking about.
Airdog 4g lift pump
PPE RACE FUEL VALVE
PVC re route
65mm upgraded turbo
51 gallon aux tank
post #10 of 15 (permalink) Old 08-14-2019, 05:30 PM Thread Starter
another thing I will say is I didn't have this issue that I remember until I let it sit for 3 months in the winter and some critters chewed up some wires. it ran really bad so I took out the harness and repaired what I could find.
Airdog 4g lift pump
PPE RACE FUEL VALVE
PVC re route
65mm upgraded turbo
51 gallon aux tank
