Water in the Fuel Filter Light - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 08-17-2019, 06:31 PM Thread Starter
Hi everyone
Am have a little problem with the Fuel Filter light it's telling me it has water in the fuel filter, We changed the fuel filter and we did the Brake & Gas peddle by hold them both at the same time with the Key on On ( Not start)
and waited a few second and the will not shut off.
Any help would be grateful
Phil
jctmotor is offline
post #2 of 4 (permalink) Old 08-17-2019, 06:41 PM
GoBlowSnow's Avatar
That little WIF sensor is known to be rather frail so check that out, probably best to go ahead and order another one, and make sure the connector is in good shape.
2008 Silverado 2500 Crew Cab Z71
GoBlowSnow is online now
post #3 of 4 (permalink) Old 08-17-2019, 06:56 PM
LHN...We ARE the Joneses
Did you drain the filter and determine if you had water?
A tank of bad fuel, plus a new filter, equals the same result....with bad fuel.
Verify you truly don't have bad fuel, then troubleshoot the sensor.
Hook'em_Horns! is online now
post #4 of 4 (permalink) Old 08-19-2019, 07:05 PM Thread Starter
Thanks Everyone
I changed the fuel filter and ordered a new Sensor
Again Thanks Phil
jctmotor is offline
