LMM Steerring Wheel Control Lights - Page 2 - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
 1Likes
post #11 of 15 (permalink) Old 01-12-2020, 07:20 PM
jakep4401's Avatar
Originally Posted by D_R_C View Post
My bad, not thinking about what lights your talking about other than what I mentioned.
Have you played with the dash lights dim and bright adjustment?
The steering wheel lights on the cruise control
Lmm Guy
jakep4401 is offline
post #12 of 15 (permalink) Old 01-12-2020, 07:34 PM
D_R_C's Avatar
The dash lights and steering wheel lights both are controlled by the same dim-bright knob switch.
Iím sure you know this, I was just suggesting adjusting it to see if maybe the steering wheel lights might start working.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #13 of 15 (permalink) Old 01-12-2020, 07:37 PM
jakep4401's Avatar
Yea it did not fix it. I did find a broken fuse but it was not for that. I watches it stop working. 1 second it was lit and then it was not. It flickered a few times a few min before it just stoped lighting up
Lmm Guy
post #14 of 15 (permalink) Old 01-13-2020, 03:46 AM
407driver's Avatar
Lmm Guy
sounds like a grounding issue in that circuit to me.
407driver is offline
post #15 of 15 (permalink) Unread Yesterday, 07:20 PM Thread Starter
lockcop's Avatar
Haven't found the culprit yet.
Kenneth a.k.a. lockcop 2007.5 LMM 2500HD ECSB 4 Wheel Drive
EFI AutoCal by Idaho Rob; DSP5 Switch In Power Port; Edge CTS2 with Pyro; Deviant Trans Lines from Alligator Performance; PPE Deep Trans + Oil Pan (TRANSYND), AFE Differential Cover + Trans Cooler from XDP; FASS T95 Lift Pump from Synthetic Motorsports; XD Tie Rods + Fumoto Valve from the DMAX STORE; ; POWERSTOP Z36 Drilled + Slotted;TIMBREN Suspension Enhancement System; Quad LED Fog Lights; OWENS diamond plate running boards; AERO 52 GAL Tank; Turbo Brake w/switch and light; Amsoil 20-50 Dominator Oil; Schaeffer Moly Grease, + Gear Lube; Temp Sensors In Oil Pan + Rear Diff; Dorman PS Cooler; Flowtie Emblem, Hillsboro 3500 Aluminum flatbed
Arizona Diesel Club #11
lockcop is offline
