Resonator delete ?? - Page 2 - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
 4Likes
post #11 of 18 (permalink) Old 10-08-2019, 06:45 AM
$14.99 PRIME Mines yet to blow off
jakep4401 likes this.
07 Bowtie LMM CCSB Z: Nice truck, mad wife, empty wallet.
With all this "gun control" talk I haven't heard one politician say how they plan to take guns from criminals, just law abiding citizens.
knotReally is offline
post #12 of 18 (permalink) Old 10-08-2019, 10:49 AM
D_R_C's Avatar
FYI, there’s no blowing out only sucking really hard like a big a$$ shop vacuum from the intake where the plug is.
You also might check it once in a while, making sure it’s still snug in place, even good quality O-rings loose elasticity and shrink overtime.
My good quality $30+ one did after only a few years, I found mine was loose, I had to replace the O-ring, the company I bought mine from sent me another O-ring.
I put my resonator back on over the plug for extra protection, just in case.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is offline
post #13 of 18 (permalink) Old 10-08-2019, 11:30 AM
Originally Posted by D_R_C View Post
FYI, thereís no blowing out only sucking really hard like a big a$$ shop vacuum from the intake where the plug is.
Hence the wink
It along with the pcv plug are two things i check when i pop the hood.
and ounce of prevention... right?
post #14 of 18 (permalink) Old 10-08-2019, 12:39 PM
D_R_C's Avatar
When I gots my pcv re-route stuff in 2008 they only had vitron caps.
A couple years later when I bought the billet resonator, billet plugs was available and included as a kit.
My pounds of prevention was to remove the caps insert the billet plugs then clamp the vitron caps over them.
Dan
DHD PCV Re-Route
AirDog 4G100
D_R_C is offline
post #15 of 18 (permalink) Old 10-08-2019, 01:38 PM
J83
J83's Avatar
ďWrongĒ
Not really, that $3 rubber cap over a short period of time it will deteriorate, crumble up and get sucked thru the turbo.
If itís just temporarily until you get the billet cap maybe.
That boost pressure is turbo sucking full force.
In fact do not use hardware rubber crap on any of the fittings, this hardware rubber is not made to withstand hot engine compartment temps.
Iíve already experienced using a plumbers plug, another guy several years ago used the wing nut that comes on the plug, I replaced it with all steel lock nuts.
His wing nut came loose and sucked thru the turbo, I went out and removed my plug the rubber had already started coming apart not sealing allowing air thru.
Do it right with the parts made for this or donít do it at all, this is the way I feel.
BTW, resonator delete does absolutely nothing.
Only the chance of the resonator cracking is reason enough, thatís all.
i dont see a difference between the rubber cap and the rubber factory bellows on the intake.
J83 is online now
post #16 of 18 (permalink) Old 10-08-2019, 02:12 PM
D_R_C's Avatar
So you don’t think rubber made for hot engine compartments is of better quality vs rubber you get from the hardware store and use in the engine compartment.
Here’s a example of hardware rubber caps that I put on my egr cooler after I by-passed it to keep crap out, this was only after 6 months.
If you think it would last much longer with massive intake suction before it crumbles and gets suck in, you’ve been out in the cold to long.
File Type: jpg 2F098756-33D4-4E23-A16D-6ED6D1532062.jpg (47.0 KB, 17 views)
Dan
DHD PCV Re-Route
AirDog 4G100
D_R_C is offline
post #17 of 18 (permalink) Old 10-08-2019, 02:55 PM
J83
J83's Avatar
So you donít think rubber made for hot engine compartments is of better quality vs rubber you get from the hardware store and use in the engine compartment.
Hereís a example of hardware rubber caps that I put on my egr cooler after I by-passed it to keep crap out, this was only after 6 months.
If you think it would last much longer with massive intake suction before it crumbles and gets suck in, youíve been out in the cold to long.
That rubber cap is meant for plumbing and waste water usage so it should be reasonably chemical resistant. Its also designed to handle the pressure of a column of water, so the vacuum on it should not really be a problem. My concern with it would be the heat, which like the picture you showed would damage any rubber, but especially rubber not made for higher temperatures. That said, i dont see the top of the intake getting that much heat compared to the EGR cooler. Im not saying its a GOOD idea long term, i just don't forsee it being a time bomb either. Theres lots of rubber in the engine bay, hoses, body mounts, engine mounts ect. Vulcanized rubber is pretty resistant to most things though.
J83 is online now
post #18 of 18 (permalink) Old 10-08-2019, 03:11 PM
D_R_C's Avatar
Ok continue using hardware rubber anywhere on your engine where your heart desires.
Dan
DHD PCV Re-Route
AirDog 4G100
D_R_C is offline
