Exhaust - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
post #1 of 6 (permalink) Old 01-26-2020, 11:07 AM Thread Starter
Exhaust
Hello everyone i just purchased a 2010 gmc duramax with 140,000 i went threw it with a fine tooth comb the highest injector balance rate was -.05 blew my mind away as they are still the original. The truck has duramaxtuner.com spade jack tuner with 5 position switch on it but everything else is stock was wanting some advice of the best exhaust not really wanting to delete the dpf and egr right now. the truck right now is getting a little over 15mpg town how much would i benefit from straight piping it but leaving the dpf on or should i wait an do the egr and dpf delete at the same time or just leave the truck alone.
thanks for any an all advise.
Scott11js is offline
post #2 of 6 (permalink) Old 01-26-2020, 11:15 AM
a8nistor's Avatar
Won't make any difference if you leave the DPF.
leave it as it and drive it
Sent from my Pixel 2 XL using Tapatalk
a8nistor is offline
post #3 of 6 (permalink) Old 01-26-2020, 11:38 AM
jakep4401's Avatar
Please take my advice and delete the dpf lol. You will get slightly better MPG but its will sound so much better and you wont have to worry about it throwing you into limp mode when it decides its full.
Lmm Guy
jakep4401 is offline
post #4 of 6 (permalink) Old 01-26-2020, 11:39 AM
jakep4401's Avatar
Lmm Guy
I did a turbo back 4" exhaust with the dsp5 switch but i used ppei tuning which is the best in my opinion. Dont use crappy tunes just spend the extra money and have it done right.
Lmm Guy
post #5 of 6 (permalink) Old 01-26-2020, 12:34 PM Thread Starter
can you delete the dpf with out deleting the egr an be fine? I am going to call duramaxtuners tomorrow and find out what tune is on the truck from what i have read most tunes shut the egr off im new to the new gen trucks ive always had 06 or older. If this is the case then yes i will delete the dpf just dont want to harm the engine.
thank you for the info.
post #6 of 6 (permalink) Old 01-26-2020, 12:37 PM
jakep4401's Avatar
Yea you can leave it on. I have mine turned off but plan in having taken all the way out before too long so i don't have too worry about coolant leaking from it. But you will be fine for awhile just leaving it turned off.
Lmm Guy
