So never did a build thread for my old truck, but figured I would do one for the new truck, not for you, but for me, so I know what I've done to it. After dumping money into my LB7 I know what I want to do to this truck, in what order....
First off, a tribute to my old LB7, she was a amazing truck, I beat the piss out of her and she just kept going, super strong, a pure and simple workhorse.
02' Silverado 2500HD CCLB 4x4 had EFI Live built trans tunes controlled by a Edge Insight CTS (tuned by Kory - PPEI), Magnaflow 4"-5" Turbo Back, Magnaflow DP, S&B CAI, PPE Boost Valve, Airdog II 165gph, BDS 4.5" Lift, Deaver 2" Mini Pack, Kryptonite UCA's, Fox 2.0 Shocks, B&W Turnover Ball Gooseneck, Tekonsha P3, Dmax Store 1 Piece Driveshaft, PPE Stage 5 Trans, Russell SS Brake Lines. Tragically, a combo of crazy rain, tires needing replacement, and me being on the race tunbe (forgot to turn it down when it started raining) ended in it being hurdled over the center divide and landing on its side. Insurance totaled her out. Please a moment of silence, RIP 12-15-2016...
That being said, cant be without a truck, need something to put hay in and haul the livestock around with. So the hunt began for a CCLB SRW, I was looking for a LBZ or LMM as I wanted something without injector or headgasket issues, and something with a Allison 6 speed. Ended up finding a white, with black interior LBZ, fully loaded LMM in Seattle, WA, after some haggling with the dealer, got down to 25k (they were asking 28k). Hopped on a plane, and 14 hours later she is home....
Need to get get weighed, VIN verified, smogged, then go sit at DMV so I can pay my taxes and registration and get my plates....
So, a list of whats going to get done over the next month or 2
-Lift pump (pulled my ADII 165 off my LB7)
-Mount my toolchest in the bed
-Pull the flares off and hopefully keep them off depending on how the paint looks, if not paint them white
-Remove some of the badging and moulding
-Paint rear emblem on tailgate
-elevation (trying to decide if I want to throw my Kryptonite UCA's on it and level it, or through 2" blocks on the rear and a Cognito or BDS 4" lift on the front) that would give me perfectly level stance and flat CV's (not to mention I have my brand new Fox 2.0's that I pulled off my old truck with the same setup)
-wheels (hate the wheels on it), and I had bought brand new SOTA SSD's for my LB7, totaled it the day before I mounted them, so they are sitting in my shop and would look great on this truck
-Nictane adapter so I can run CAT filters
-Buy a VIN license, get some mild stock trans tunes, block EGR, remove cat and DPF (will need to put it in every other year for smog)
-Replace headlights with LED's
-Some Weathertech floormats
-Replace the nerf bars with N-Fabs (i bought a set for my LB7 and they arrived the day I totaled it, so will exchange for ones for this truck)
-Fluids, treat her to Amsoil full synthetic (front diff, read diff, transfer case) flush coolant, dump and fill + filter on the trans, just got her oil changed so im ok there...
-3 pod pillar gauge mount (EGT, boost and oil temp)
-backup camera (makes hitching up the bumper pulls so much easier)
And other stuff thats planned-
-Front bumper, I did a Road Rhino WIY on the last truck, debatting between that or a Trail Ready, love the look of the trail ready, but they are $$$$$
-Built trans
-air bags
-onboard compressor
-weld up a headache rack
-most likely replace the rear bumper with something heavy duty
And build/VIN Info...
How she sits currently...
-Built trans
-air bags
-onboard compressor
