Fuel filter - Page 2 - Chevy and GMC Duramax Diesel Forum
 8Likes
post #11 of 21 (permalink) Old 10-23-2019, 11:43 AM Thread Starter
Fireman12983's Avatar
Anyone ever had an issues with truck blowing white or blue smoke. Was running the truck on the highway for 10 minutes stopped at store and when I started it back up it was blowing white/blue smoke from exhaust. Only happen once, no change in power. It is a '15 Silverado LML, bone stock, just did the fuel filter 3 weeks ago
Fireman12983 is offline
post #12 of 21 (permalink) Old 10-23-2019, 07:15 PM
what fuel filter did you use?
2002 GMC 2500HD, ECSB, 4WD, LB7
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned by me now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
2016 GMC Denali stock for now
gmc502 is offline
post #13 of 21 (permalink) Old 10-23-2019, 07:55 PM Thread Starter
AC delco
post #14 of 21 (permalink) Old 11-20-2019, 01:00 AM
KenW56148's Avatar
Fuel filter change
. just did the fuel filter 3 weeks ago
Changing the filter.....
How are you accessing the filter. From top or thru fender well? I can not figure the best /easier way. This is a stock 2016 LML. Thanks for the advise.
Ken
2016 Silverado 2500HD LTZ 4x4 Crew cab
KenW56148 is offline
post #15 of 21 (permalink) Old 11-20-2019, 06:25 AM Thread Starter
I got to mine through the fender. I have a 6" lift though and 35's so I didn't even need to pull the tire, just remove the fender well.
post #16 of 21 (permalink) Old 11-20-2019, 08:07 AM
Sierraluva's Avatar
Blackjack fuel filter panel.
🤘 Kennedy fuel system support hardware, CCM front Diff Drop, some LEDs to make night into day, got some big ol 20's and wide ass tires and a nice display to show me what's up under the hood-
2012GMC2500CCSB
Sierraluva is offline
post #17 of 21 (permalink) Old 11-20-2019, 12:04 PM
redwngr's Avatar
On LML it is necessary to go in thru the wheelwell.
redwngr is offline
post #18 of 21 (permalink) Old 11-20-2019, 12:15 PM
J83
J83's Avatar
Pre delete i would get a lot of white smoke, more in the winter, though i think it was mostly water vapor. Ive heard that leaking ERG coolers can cause white smoking though as coolant is introduced into the cylinder by the leaking cooler. Blue smoke would be burning oil, that should be unlikely on a truck this new, sure it wasn't just light black smoke?.
This is by FAR the easiest way. 30 minute install of the kit, 2 minute filter changes there after. No wheel well liner, no reaching around tires. Done. *Does not work with dual alternators, ask me about my new 140 amp paperweight*
https://www.amazon.com/Duramax-Fuel-...4277391&sr=8-1
J83 is offline
post #19 of 21 (permalink) Old 11-20-2019, 04:11 PM
heres a question,,will the original dmax filter(2001-2010) fit the 2016 filter head?
gmc502 is offline
post #20 of 21 (permalink) Old 11-20-2019, 04:21 PM
LHN...We ARE the Joneses
Same filter. The filter head difference is it has no fuel heater.
Hook'em_Horns! is offline
