2015 LML Knock or weird sound around 2000 RPMs. PLEASE HELP - Chevy and GMC Duramax Diesel Forum
post #1 of 1 (permalink) Old 10-14-2019, 11:39 AM Thread Starter
I recently completed a cp3 converison on my 2015 LML after the cp4 blew up. I bought the whole kit (pump, rails, lines, injectors, etc) from DMAX store which is from S&S diesel. I also deleted the EGR while I was at it. Cleaned everything out including the tank and lines going to the engine bay. Programmed the injectors into the ECM and GPM with the codes from the new injectors using a snap on tool. Also installed a FASS 165 with draw straw. The trucks runs fine until i get to 2000 RPMs and then it has a weird sound coming from engine. It sounds like an injector knock. It also throws a code P026D after this sound. There is also a MAP sensor code P0107. I installed a brand new MAP sensor and it still throws this code. The wires to the sensor that goes into the intake manifold close to the MAP sensor got a little messed up during the reinstallation of everything so I am trying to order that sensor but cannot find a part number for it (maybe one of y'all might know what the PN is ). Using my edge CTS, it does not read any boost pressure , so I'm guessing this is causing problems. I know there's a lot going on here, I'm just hoping one of y'all might be able to shed some light on what is going on.
Thanks
2015 LML
Mods:
5" Exhaust, EGR Delete, CP3 Conversion, FASS 165, Calibrated Addiction Tuning
2005 LLY
Mods:
Exhaust, EGR Delete, Wherli Y-Bridge, Head Studs, II CP3 BOP, Powermax Turbo, FASS 150, Edge CTS, and PPEI Tuning
HANSE is offline
