15 lml problems - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Unread 11-11-2019, 12:46 PM Thread Starter
15 lml problems
2015 gmc denali lml dmax. Truck was fully delted, 5 inch straight pipe, 66mm turbo, ppei tunes. All work was done in april this year and truck has ran fine until last week when temperature dropped below 50 degrees started running intermittent and loses power and has a bad vibration. But when it warms up above 50 degrees it runs fine again. Any tips?
Denhd1987 is offline
post #2 of 6 (permalink) Unread 11-13-2019, 05:12 PM
poosniffer's Avatar
Sounds like your fuel has gelled. Try getting your truck into a heated garage and add a healthy dose of anti gel like Power Service or Lucas.
2018 Toyota Tundra Platinum Crewmax
SOLD:2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket DSP5 calibration by Danville Performance, Blocked and re-routed, Nicktane with Baldwin BF7587, PPE lift pump with Baldwin BF1212 water separator, 285/75/17 Dura Grapplers on H2s, CTS Insight with pyro.HIDs in fogs and high beams.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline
post #3 of 6 (permalink) Unread 11-13-2019, 06:35 PM
Gelling at 50 degree's (F I assume ) seems unlikely. I assume this is outside temp and it run poorly until the outside temp gets up around 50?
Not an expert here - just trying to clarify.
2015 3500 LTZ Dually
B&W Turnover & Companion
40G Transfer
Chakara is offline
post #4 of 6 (permalink) Unread 11-13-2019, 07:59 PM
SilverGorillaLML's Avatar
Not gelling at that temperature.
Race/Pulling truck:2012 Cummins/Built 6.8L/Big air/Big fuel/48RE Swap/PCS 2000/B&M Gated shifter
Playing eye spy for another duramax
SilverGorillaLML is offline
post #5 of 6 (permalink) Unread 11-14-2019, 06:24 AM
Riley 1820's Avatar
Change fuel filter. Add anti gel. Buy good fuel. Check for air leak. Bad o ring could leak when cold.
2012 3500hd srw 4 wd Jamco exhaust Kennedy dual lift pump Trifca bed cover B& W gooseneck hitch Western Diesel fuel filter relocation bracket
Riley 1820 is offline
post #6 of 6 (permalink) Unread 11-17-2019, 02:38 AM
poosniffer's Avatar
LOL, yes you're right. We have had some nut numbing temps around here lately and forgot about the rest of the country.
