Oil change gone bad - Page 4 - Chevy and GMC Duramax Diesel Forum
 42Likes
post #31 of 39 (permalink) Old 11-27-2019, 12:01 PM
J83
J83's Avatar
Originally Posted by Montucky View Post
@J83 it was a steel bolt and a steel pan on a freightliner M2 with a cummins ISC engine. The design of the drain plug is such that the shoulder of the bolt is to thin and thus cracks form, especially if over tightened; and like I said eventually failure. Iíve actually seen it several times and have the drain plug in my rig for show.
My point was more like shit happens and they are a machine and things fail. Itís most likely this was a double gasket situation as thatís more common.
Oh ok, i thought we were talking about on the duramax here. That makes more sense.
J83 is offline
post #32 of 39 (permalink) Old 11-27-2019, 01:32 PM
I won't let either the Chevy or GMC dealer in my area change mine. I've stood and watched them. Even if properly trained, they don't seem to have the integrity to do it per their training. Left without supervision, they'll do it however they want to. And you can forget about a proper grease job. Not to mention, it's usually a different guy every time you go in there. Sorry, but the oil change guy in most dealers is just a half step above the wash boy. ( (I've done both jobs back in the day and I am sure there are exceptions to what I just said. =Not trying to come off better than anybody else, just stating my experience........64 years worth)
The Silver Fox likes this.
mike5511 is offline
post #33 of 39 (permalink) Old 11-27-2019, 01:42 PM
redwngr's Avatar
Pick any occupation you like.
There WILL always be examples of some that shouldn't be doing it.
redwngr is online now
post #34 of 39 (permalink) Old 11-27-2019, 03:07 PM
J83
J83's Avatar
Thats been my experience as well, however i just grease the truck myself and let them change the oil, because the "life time" oil change plan i got on the truck comes out to like 18$ oil changes by the time i trade it back in. I like to drive the wheels off my trucks...
I took the wifes cruze in for an oil change at the dealer. Brand new diesel cruze... bought from that dealer..... took them 2 hours to figure out how to get to the oil filter. There words.... not mine.
True, however the importance is in the percentage of people in that occupation that fall into that category. Engineer, Doctor, Baker, usually going to be pretty low. Lube tech, dealer mechanic, maybe not as low...
J83 is offline
post #35 of 39 (permalink) Old 11-27-2019, 10:16 PM
Originally Posted by Jbeck1986 View Post
This is why I donít let anyone change my oil. I have had friends who worked at quick lube places that have told me horror stories like this. Or worse. Like starting it up with no oil and not noticing till thereís a knocking coming from engine. Then just adding the oil and never saying a word to anyone and sending it out to the customer.
A few weeks ago I had my tires rotated at the tire shop down the way. Asked them to lube grease points since I hadnít had a chance since buying this truck. I asked him how many there were after. He said one on each side. I thought that sounded strange but havenít had a vehicle this new or a duramax diesel. So I didnt wanna tell him he was wrong with out checking. Checked and found out there was a total of 9! Was beyond pissed.
I ended up calling the shop foreman for something else since I work at a RV repair shop and we use each other of service at times. I mentioned this situation and before I could finish he said it should be 9 or 11 depending on the year. Then said only he and one other guy would have known off hand. I told him that I was going to be requesting him to do the work on my truck when I come by for now on. He was glad to do so and appreciated that we didnít have this discussion in front of the entire crew or in front of customers.
My point is either you make sure you can trust who you have working on your truck or you do it your self. Changing the oil in these trucks can usually be done with out a jack most of the time.
If he was much of a foreman he would make sure the crew knows so every customer is taken care of the right way
mackman is offline
post #36 of 39 (permalink) Old 11-28-2019, 03:26 PM
Ineedabiggertrailer16's Avatar
No excuse for that, ESPECIALLY from dealer techs. Have the never heard of the world class research firm of Google & YouTube?
16í C.C. LT. Tinted, Weather Techs, Boost Tow mirrors, leveled/Moto930s/35Ēs, Kennedy, Ridge Runner, May Truck Parts exhaust
Ineedabiggertrailer16 is online now
post #37 of 39 (permalink) Old 11-29-2019, 03:55 PM
J83
J83's Avatar
Apparently not. My local dealer is terrible though.
J83 is offline
post #38 of 39 (permalink) Old 11-29-2019, 03:57 PM
LHN...We ARE the Joneses
Meh....you're closer to Russia.
Hook'em_Horns! is online now
post #39 of 39 (permalink) Old 12-03-2019, 01:14 PM
KenW56148's Avatar
Originally Posted by 407driver View Post
Too Busy?
You mentioned right off that you had two oil change apprentices with nothing to do.
<img src="https://www.duramaxforum.com/forum/images/smilies/rofl[1].gif" border="0" alt="" title="Rofl" class="inlineimg" />
Precisely where I learned how to maintain my vehicles. <img src="http://www.mysmiley.net/imgs/smile/innocent/innocent0002.gif" border="0" alt="" title="innocent0002" class="inlineimg" /> What little boy doesn't want to do what he sees daddy doing?<img src="http://www.mysmiley.net/imgs/smile/confused/confused0082.gif" border="0" alt="" title="confused0082" class="inlineimg" />
No kidding- dad would talk to mom about the busy day he would have this coming weekend.... four boys at home.... get the picture. Tuff job supervising. &#x1f604;
(You want to drive it...then know how to work on it)
Ken
2016 Silverado 2500HD LTZ 4x4 Crew cab
KenW56148 is offline
