Transmission Fluid Cold Check - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 11-22-2019, 09:45 AM Thread Starter
I changed the fluid and spin on filter on my 16. I replaced the fluid with what came out, about 7 qts. I did a cold check on the fluid and it was super low, about an inch under the cold marks. I've read about the cold check procedure but had a couple questions. Is it just for initial startup or is there a cold temp range like the 165-200 hot range? Its around 20 deg here so its difficult to get a hot check and the truck wants to go in high idle which may affect it also. Trying not to overfill and have a bigger headache. Thanks for any info.
Tombmx is offline
post #2 of 3 (permalink) Old 11-22-2019, 08:58 PM
redwngr's Avatar
I don't think I've heard/read of a 'cold check' temperature range.
Just the 'cold check' steps from the Duramax supplement.
(probably why the cold check level is also a band)
redwngr is offline
post #3 of 3 (permalink) Old 11-23-2019, 07:33 AM
I did my 16 a month ago. Noted dipstick before the change. Drained and did the spin on then measured exactly what came out, put exactly that much back in plus about 8 oz for the filter. Came out perfect. It won't hurt to be just a tad low. Run it for a while and check it again.
2016 LML White Denali HD 2500 leveled
SODA Novocain Wheels
Amp Steps
Air Dog 100
Bean Sump
Bilstein 5100
Bushwacker color matched
Ridge Grapplers
Putco Bed Rails
JETPIG is offline
