P2771 & p0700 help asap - Chevy and GMC Duramax Diesel Forum
 4Likes
post #1 of 22 (permalink) Old 12-07-2019, 07:54 AM Thread Starter
deez112's Avatar
I own a 16 chevy 2500hd LML 4x4 and I have recently changed transfer case fluid and front and rear diff. Randomly I get 2 codes, when I'm driving through town(stop and go traffic) P0700-trans control system - circuit malfunction & P2771-4x4 low gear circuit circuit malfunction. What I'm confused about is. This trck has used 4x4 low, probably 2 times its entire life(since i bought it off the dealership lot in 2016) I use 4x4 High everyday to get up my driveway. But always attempt to make sure I'm out 4x4 after i get to the top of my hill.... please help, this is my daily driver. I'm not sure where to begin to look at exposures to wires. Thank you for you're help!
16" LML LT BLACK HAMMER
5"Jamo
ANARCHY EFI LIVE
FASS165GPH/FASS HEATER
G&R SUMP
Block-off plates
INSIGHT EDGE CTS2
SPYDER AUTO TAILS
CougarMotor LEDs
Morimoto Fogs
deez112 is online now
post #2 of 22 (permalink) Old 12-07-2019, 08:46 AM
CDmax16's Avatar
How often are you getting the codes?
Wehrli intake bridge and AFE IC piping,Edge Insight cts2, AirDog II 165,SDP resonator delete, Mishimoto pcv catch can, MBRP down pipe,Recon led tail lights and third brake light, Morimoto mini D2S 5.0 projectors w/hidís, Morimoto 2stroke 2.0 ledís highs and fogs.
Kryptonite ucaís & tie rod sleeves, CCM diff drop,Fox 2.0 reservoirs, steering stabilizer, CalTracs,
Cognito PISK and heavy duty sway bar links, AirLift bags...
CDmax16 is online now
post #3 of 22 (permalink) Old 12-07-2019, 09:06 AM Thread Starter
deez112's Avatar
It was rare. Then, the other day it popped up on my way to work. So, I changed fluid in transfer case and front and rear differentials. After I changed fluids, it was gone. But, then yesterday I was in town doing errands, and it popped up yet again. I have noticed that it's getting harder to put gear shifter in Park.
5"Jamo
ANARCHY EFI LIVE
G&R SUMP
Block-off plates
INSIGHT EDGE CTS2
SPYDER AUTO TAILS
CougarMotor LEDs
Morimoto Fogs
post #4 of 22 (permalink) Old 12-07-2019, 09:36 AM
CDmax16's Avatar
Mine does it every once and while as well. I have researched it and talked with others that have had the same codes, and unfortunately, I have not heard of a solution yet. I donít remember everything that was tried by different people, but a few things were, 4 wheel drive switch, checked the wiring and connections at tcm trans and tc and nothing worked. And one guy put in a new tcm.
Itís hard to diagnose when it is so random. I got the codes maybe half a dozen times the first two years and then earlier this year it happened about 4 times in a month and I thought here we go, something is going to break and at last I will figure it out. Nothing broke and it hasnít happened since ( I know I just jinxed myself). The concerning thing for you is the putting it in park issue, mine doesnít have any other issues.
Hopefully you can find the problem or someone else will chime in and help out. I will go back and look at my old conversations about this and see if something doesnít help.
post #5 of 22 (permalink) Old 12-07-2019, 10:18 AM Thread Starter
deez112's Avatar
See, the even more weird part is, my transmission doesn't start to act up and shift harder, until that light comes on. Truck shifts fine 1st good 2,3, then going into 4th so rapidly but, I think I am going to do a trans relearn and hope that fixes it. If you don't mind me asking CDMAX16 Cou lml d you tell me the proper procedure to trans relearn process
post #6 of 22 (permalink) Old 12-07-2019, 11:11 AM
P02771.pdf
Fredn3ck likes this.
Ron Nielson
Ron Nielson is online now
post #7 of 22 (permalink) Old 12-07-2019, 01:29 PM Thread Starter
deez112's Avatar
Originally Posted by Ron Nielson View Post
This is for an 08, is it the same procedure?
5"Jamo
ANARCHY EFI LIVE
G&R SUMP
Block-off plates
INSIGHT EDGE CTS2
SPYDER AUTO TAILS
CougarMotor LEDs
Morimoto Fogs
post #8 of 22 (permalink) Old 12-07-2019, 01:33 PM Thread Starter
deez112's Avatar
Hopefully this may help a little more
5"Jamo
ANARCHY EFI LIVE
G&R SUMP
Block-off plates
INSIGHT EDGE CTS2
SPYDER AUTO TAILS
CougarMotor LEDs
Morimoto Fogs
post #9 of 22 (permalink) Old 12-08-2019, 07:54 AM Thread Starter
deez112's Avatar
Bump
5"Jamo
ANARCHY EFI LIVE
G&R SUMP
Block-off plates
INSIGHT EDGE CTS2
SPYDER AUTO TAILS
CougarMotor LEDs
Morimoto Fogs
post #10 of 22 (permalink) Old 12-08-2019, 11:10 AM
redwngr's Avatar
Since the descriptions are 'circuit faults' seems they would electrical issues, rather than a fault with the item(s) being monitored.
P0700 is something with serial communication to TCM
P2771 is a status/logic problem with 4WD Low switch.
Have you verified connectors/harness connected and not damaged?
I'd think changing fluid wouldn't have anything to do with either one -- unless a harness/connector was moved during the process.
redwngr is online now
