HELP with removing DEF/ urethra injector for replacement - Chevy and GMC Duramax Diesel Forum
 9Likes
post #1 of 17 (permalink) Old 12-09-2019, 09:38 AM Thread Starter
I have a 12 LML that is showing Exhaust fluid quality poor message and at this point I'm limited to 55 MPH so driving a borrowed vehicle.
I took it to a shop since I haven't been able to clear that message I've done the RFQT test a few times and always fails I ran through the full battery of tests where I do a service regen then the RFQT but it still fails. The downstream Nox sensor is normally about 70% less (120 UP and 30 down) but its still failing.
Mechanic thinks issue is with the Def injector the stream might not be clean / good shop was closing so I just ordered one from Rock auto waiting for it to arrive today but the Magical question is how do you remove the injector so I can try and actuate the injector outside the vehicle to see if it is truly bad or not. The below picture shows how I removed the locking plate. I've tried to twist and pull but the injector isn't coming out am I missing a release spring or something?
There were some ECM updates that were also done but still no change.
I just want to remove the injector and test it to see if it is actually spraying. I can disconnect the line and actuate the pump and it will pump out the fluid no issues.
I'm open to ideas on how to remove this or what else i can try / do. I do have a hand held scanner that can do everything the Tech 2 is able to do.
2012 Chevy Silverado 2500 Silver.
aFe Power Magnum FORCE 51-11922 CIA
Everything else stock
mario430 is offline
post #2 of 17 (permalink) Old 12-09-2019, 12:32 PM
What scanner do you have that can do everything a Tech 2 can?
Nitro Junkie is online now
post #3 of 17 (permalink) Old 12-09-2019, 12:58 PM Thread Starter
From Amazon its the Launch X431 PROS Mini Bi-Directional Diagnostic Scan Tool Full System Automotive
I can NOT update firmware but can run tests and see sensors and all that fun jazz
mario430 is offline
post #4 of 17 (permalink) Old 12-09-2019, 01:16 PM
That's the part I was wondering about.
post #5 of 17 (permalink) Old 12-09-2019, 09:47 PM
I am wondering about the "urethra injector". I might be wrong but all us little boys have an injector😜
2019 Chevrolet 4500HD CC 4X4 Flatbed
2018 Chevrolet 1500 CC 4X4 High Country 6.2 liter
2019 Chevrolet 3500HD CC 4X4 Flatbed--SOLD
2011 Peterbilt 337 hauler with 360HP 8.3 Cummins--SOLD
1957 GMC 1 ton flatbed with 22K original miles.
3 different Kubotas
2003 Chevrolet 2500HD CC: 2011 Chevrolet 3500HD CC 4X4 and 2013 3500HD ex. cab 4X4-- all sold.
sambor is offline
post #6 of 17 (permalink) Old 12-10-2019, 07:30 AM
Ineedabiggertrailer16's Avatar
Bruce Jenner could probably advise on removing your urethra.
Iím sorry I couldnít pass up that joke Found this on YouTube
16í C.C. LT. Tinted, Weather Techs, Boost Tow mirrors, leveled on 35s, Kennedy pump, Ridge Runner, May Truck Parts exhaust
Ineedabiggertrailer16 is offline
post #7 of 17 (permalink) Old 12-10-2019, 08:30 AM
I figured you or Hook would respond first!
3 different Kubotas
sambor is offline
post #8 of 17 (permalink) Old 12-10-2019, 10:49 AM
long-time-dmax's Avatar
Sounds painful don't it?
Dales Super Store likes this.
2002 Chevy 2500HD Crew - Original owner - 408,000 miles so far. All stock with the exception of a lift pump.
long-time-dmax is offline
post #9 of 17 (permalink) Old 12-10-2019, 06:07 PM
J83
J83's Avatar
Rule 34 of the internet.
J83 is online now
post #10 of 17 (permalink) Old 12-11-2019, 08:11 AM Thread Starter
https://m.youtube.com/watch?v=PmQgP7CxG4I
Ironically that is the video I was watching but the damn thing wouldn't come out so that is why I was asking if I'm missing something else.
mario430 is offline
