Chevy and GMC Duramax Diesel Forum (https://www.duramaxforum.com/forum/)
-   11-16 LML Duramax Powertrain (https://www.duramaxforum.com/forum/11-16-lml-duramax-powertrain/)
-   -   Elevated idle not working (https://www.duramaxforum.com/forum/11-16-lml-duramax-powertrain/1003193-elevated-idle-not-working.html)
Durmmax 12-12-2019 03:26 PM
I turned on the elevated idle a few weeks ago. My trucks been sitting for a full day and it’s 29 degrees out. Went outside and started the truck. Coolant temp was 39 degrees and outside temp 29 but no high idle kicked on. Am I missing something ? 2011 LML
sambor 12-14-2019 06:43 PM
What do you mean "turned on the elevated idle?
Normally you don't have to do anything- if its cold enough it will ramp up the idle speed after a small period of time.
Later in the post you mentioned "high idle"". Two different things- high idle is an option, elevated idle is on all dmax's except maybe the first ones.
denarli6.6 12-14-2019 07:03 PM
Elevated idle can be turned on & off. High Idle is different than elevated idle. Revs up to a higher RPM and initiated by pressing the parking brake and the cruise control buttons (at least on my yr model truck). How long did you let the truck idle for? I have my elevated idle tuned on my truck and it has yet to turn on this year as well. Most of the time its cranked in the garage but a few times at work it hasn't come one. Been waiting for it to get colder and park it outside for the night to see if it works.
gmc502 12-14-2019 08:33 PM
mines kicked on at least a half dozen times already.
denarli6.6 12-14-2019 09:29 PM
That's kinda all relative to where ya live haha
redwngr 12-14-2019 09:47 PM
GM's instructions really added to the confusion by the way they describe the warm-up feature:
Cut and paste from 2011 manual:
Elevated Idle
The engine has a cold temperature high idle feature which elevates the engine idle speed from base idle to 1050 rpm for pickup models or 1200 rpm for van models when outside temperatures are below 0C (32F), and the engine coolant
temperature is below 65C (150F).
This feature enhances heater performance by raising the engine coolant temperature faster.
This feature can be turned on or off using the DIC buttons. If the vehicle is not equipped with DIC buttons, do the following to turn this feature on or off:
1. Turn the ignition to ON/RUN, with the vehicle off.
2. Press the accelerator pedal to the floor and hold while quickly pressing the brake pedal three times in less than eight seconds.
3. Release the accelerator pedal and start the engine.
When the engine is started, it will slowly ramp up to the high idle speed after a delay of a few seconds up to approximately
two minutes.
For this method to work properly there must be no throttle or brake pedal faults.
The engine idle speed will return to normal once the following conditions are met:
. Once engine coolant temperature reaches 65C (150F).
. Air intake temperature reaches 0C (32F).
The high idle speed will be temporarily interrupted and the engine speed will return to normal if any of the following conditions occur:
. The brake pedal is applied.
. The accelerator pedal is pressed.
. The transmission is shifted out of P (Park) or N (Neutral).
. Vehicle speed is detected.
Once these inputs are removed, the engine idle speed will slowly ramp back up to high idle after the normal delay, if the conditions for engine coolant temperature and air intake temperature are still met.
There are separate instructions for the optional Fast/High Idle feature that is operated with the cruise buttons.
gmc502 12-15-2019 08:15 AM
yup,and its been cold up here in MA lately,,yet today mid 40's.time to wash the truck.
Durmmax 12-15-2019 12:25 PM
I activated the elevated idle as stated above by pressing the gas pedal and hitting the brake 3 times and it came up in my DIC that it was activated. The other morning it was 29* and the engine was ice cold. I started the truck and it idled for 10 min at 7-800 rpm until I drove off.
Powered by vBulletin® Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
