"Must Do" items after buying used? - Page 2 - Chevy and GMC Duramax Diesel Forum
 13Likes
post #11 of 15 (permalink) Old 12-19-2019, 08:32 AM
Dales Super Store's Avatar
Originally Posted by mwswarrior View Post
If it wasn't detailed, I'd get a used vehicle detailed including a good under carriage and engine bay cleaning. This makes leaks and other issues easier to detect.
That is good advice
844-487-2787
PM us for special pricing
Operating Hours: 9am-6pm EST Monday - Friday
Dales Super Store is offline
post #12 of 15 (permalink) Old 12-29-2019, 10:29 AM
Using a fuel additive was mentioned on here; is that used during every fuel up I'm assuming? Thanks all for the info!
Beau J McKinney is offline
post #13 of 15 (permalink) Old 12-29-2019, 10:49 AM Thread Starter
I'm with the others here in resetting all maintenance I can do so it's fresh and a know the timeline and that it's done right with right fluids and filters. this would include oil, trans, diffs, xfr case, air & cabin filters.
I would also take a look at the coolant and depending on mileage change it too.
Some fuel treatment to clean the system.
Take a close look at tire wear to see if an alignment and rotation is needed or perhaps some wear items or idler and pitman. No need to ruin good tires!
I also usually get a good set of mats to save the carpets at the outset.
Recently I started replacing the headlights and driving lights with quality LEDs that are typically brighter and will definitely last A LOT longer than typical replacements.
Do you have any more details on which fuel treatment and which LEDís you recommend?
Sent from my iPhone using Tapatalk Pro
_CROW is offline
post #14 of 15 (permalink) Old 12-29-2019, 02:07 PM
D_R_C's Avatar
Additives; That can depend on if you have Bio fuel where you buy your fuel.
I use additives in every tank, some just uses once in a blue moon this doesn't really do anything for long term.
If you use the search option on this forum you'll find lots of fuel additive discussions on your ?
You'll have way more suggestions on what's best than what your really looking for.
Including some that just refuses to use additives. why.
I use Diesel Kleen with a little LUCAS fuel additive every fill-up since I've owned my truck new 6/2/07, cost about $1.25 per 32 gallon tank which equals to only about a 3-4 cents per gallon increase over the cost of the fuel per gallon.
Pretty inexpensive insurance.
If you find a additive you like buy in the gallon containers and put the amount you want to add in smaller bottles, this will save you mucho $$$.
_CROW likes this.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #15 of 15 (permalink) Old 01-01-2020, 07:20 PM
mwswarrior's Avatar
Originally Posted by _CROW View Post
Do you have any more details on which fuel treatment and which LED’s you recommend?
Have used Power Service products for all my diesels with great results for the past 20 years changing the product depending on temps. I've used them in deep freeze weather (<-30deg F) and in the desert (>115deg F).
For LEDs I've used Beamtech on several vehicles and have yet to replace any. Great light, not too bright or obnoxious. My oldest set is on my '14 Diesel Cruze and they're about 4 years old. Just put highs and lows on my ZR2 and replaced the OEM fogs on my Tahoe. You can find them on their own website or on Amazon.
_CROW likes this.
'18 Colorado ZR2 LWN 2.8L Diesel.
De-badged & Flagged. Soon to be "Bison'd"
'09 Sierra 2500HD LMM CCSB--SOLD
'05 Silverado 2500 LLY CCSB--SOLD
Other:
'14 Chevrolet Cruze Diesel
'19 Chevrolet Tahoe 6.2L
GO NAVY! BEAT ARMY!
mwswarrior is offline
